Windows 7: Famous Win7 64bit low volume microphone problem
22 Sep 2014   #1
danilpro
Windows 7 Professional x64
(( Sorry, this topic should be in audio and sound forum. Admins please move it ))
Hi guys. This is an old, very ugly problem, still without clear solution. I'll start from the beginning, and sorry for my English.
Two weeks ago, I had spanish Windows7 64 bit computer and my Gamecom 360 headset with microphone that was working really fine with 50 volume and 0db additional boost. Then, one beautiful evening, the lights in my house went off, and my HDD partition broke, so did Windows. I had to install a new copy from the different source, so this is when I faced this famous problem my microphone was really, really low with 100% volume, something that cannot be. I did all this tricks people tell you to do in "sound" menu, but no results..
Also, I did everything you can do in Realtek software without any effect.
Drivers
My sound card is integrated, motherboard is ASUSTeK COMPUTER INC. P8H61-M LX (LGA1155). Sound card details are here:
I've tried 4 different versions of Realtek drivers. 1 - From motherboard website. 2 - Realtek website according to OS. 3 - Especial drivers for soundcard model from Realtek website. 4 - Ac97 drivers. None of them worked. No effect. Headphones work just fine, but mic only shows good green sound level in "Sound" config if I hit microphone "head" pretty hard with my finger.
I've tried other win7 64 bit package (different source), no effect. I looked into BIOS, searching for some power suply settings pointing especially to sound devices.
Today I've tested my headset on two different computers, mic was low on both. Well, I bought a simple stick mic for 5$ dollars, connected it and ... nothing.. The same low volume crap.
I am really desperate right now, because I just don't know what else I can do here. I even emailed to Realtek guys, but still got no reply. I don't know WHY it is happeng, where should I look. Before windows crashed, I could record perfectly with 50% volume, but now 100% is not enough at all.
A lot of people talk about "Microphone boost" option in "sound" menu but I don't have this feature, I guess that's because my hardware doesn't support it.
I am an youtuber and I really need my micro to work..
Obviously, I did a huge research about this topic, especially on this very site. Some of the threads have more than 60 000 views and surprisingly there is still no clear solution. Some people do random things in "sound" panel, marking or removing all the checkboxes they see there and some of them fix the problem going that way. I've tried everything without results. Everyone blame Win7 in those threads. I don't know really who can I blame.
I forgot to say, I've tried frontal and rear panel access.
Just now I have one possible solution: to buy an USB adapter, maybe this could solve the issue. But where the hell can I get that thing, living in Latvia, no freacking idea.
Windows Troubleshooting also identified "low recording sound" but is unable to fix it. I downloaded "Windows Fix audio recording" tool but this thing gave me "validating the integrity of the troubleshooter failed 0x800b0101" error. I am so lucky.
So that's all I wanted to post. I don't really expect some usefull tricks to resolve the issue, maybe some people will find this post interesting and it could help them.. I dunno.
If some of you guys can help, please do so. Have a nice day.
22 Sep 2014   #2
PSCO2007
Windows 7 Professional X64
Right click audio icon and select mic>properties and level.
Check to see the level and increase it.
22 Sep 2014   #3
danilpro
I checked this things a hundred times. Please reread my post with more attention.
22 Sep 2014   #4
PSCO2007
Sorry to have bothered you.
22 Sep 2014   #5
Anshad Edavana
Hi
Have you tried increasing microphone boost along with volume ?.
how to boost microphone volume in windows 7 - YouTube
22 Sep 2014   #6
danilpro
Quote   Quote: Originally Posted by Anshad Edavana View Post
Hi
Yes, I have.
Microphone volume too low
Just installed the release candidate of Windows 7. Was previously running Vista. I use Skype a lot, and my microphone volume level is much lower now than it ever was. People are telling me they can hardly hear me when I call them. I have a Dell Inspiron 1525 laptop- the mic is built-in. I've...
Microphone volume is agonizingly low
Every textbook way to fix the mic being low has failed for me. Can anyone help? It needs to be pretty much be in my mouth to be a decent volume. Microphone levels at max + boost? Tried it. Set the correct microphone port as default device? Tried it. Double check communications tab to...
Problem with Windows 7 and Microphone Volume
Hey guys, I recently put together my custom system and the audio is fine, but im having problems with the Mic volume. No body can hear me. I have an ASrock 970 Extreme 3 Mobo, W7 Home Premium 64bit. I have the volume on 100, boost on 30, and have been messing with all the settings. The green...
Microphone volume reduced
Hello All, I did a fresh Windows 7 installation on a new hard disk drive on my laptop.I am using Dell Inspiron 1525 laptop.However, after installation the microphone seems to be behaving weirdly(volume has reduced).I see that the system is automatically adjusting the volume of the...
Microphone volume won't stay put
I want to lower my microphone volume from 100 to 50. When I do it, it will stick around for a little while (while I record something), but then it will jump back to 100 sometime after I'm done or even before I start. For some reason, the adjustment just won't be saved. I'm hitting OK to close the...
