Windows 7: Connecting 2 HDD's onto same power cord.
23 Sep 2014   #1
SevSaint
Microsoft Windows 7 Home Premium 64-bit
I am wanting to install another HDD and possible a 3rd in my computer. Each dedicated to movies, pics, etc...
If i use one power cord will that work and if so should i be concerned with overall power supply?
MSI z87 g55 Mobo.
Through my mobo i can disable the other drives from booting and still use them for storage correct?
23 Sep 2014   #2
strollin
W10 Pro desktop, W10 laptop, W10 laptop, W10 Pro tablet (all 64-bit)
I suppose you could get really crazy and overload the psu with too many drives but, for the most part, you can use splitters to be able to supply power to additional drives.
You can specify which drive is the boot drive so, yes, you can use the other drives for storage. It's best though to format those drives to remove the old OS and claim it's drive space in order to increase available storage space.
23 Sep 2014   #3
SevSaint
okay.. i read up that most hdd only use 12v of power and most of the time are idle and my corsair 600w has several connectors on the same power cord
23 Sep 2014   #4
SevSaint
One quick question. Just installed the drive and its broken down into 2 volumes. A f, and a G drive both set at 250gb each. I want to make these volumes one and erase everything on them. How do i do that.
23 Sep 2014   #5
SevSaint
LOL nvm, with a little tinkering under management i deleted both sectors and did a new volume, simple as that
25 Sep 2014   #6
kbrady1979
Most power supplies come with a SATA cable with 2 or 3 SATA power plugs on it so yes, it's perfectly fine to use one cable for multiple drives.
25 Sep 2014   #7
Berton
Just for clarity, it's the SATA Data Cable that can't be split, only one drive per cable. That's different from the 40-pin or 80-pin PATA cable that has 3 plugs, one for the motherboard [end plug], one for the Master drive [other end plug] and one for the Slave drive [middle plug] and they are usually marked as to which is which.
Laptop Power Cord
My girlfriend has been bedridden due to an operation. I put my laptop on the bed so she can use it when I get up and put it in the case at night. I leave the power cord plugged into the wall all night but no PC plugged into it. There is a light on all the time on the rectangular thingy on the cord....
General Discussion
HP Power Cord Recall
Received this warning this AM for the LS-15 cord: https://h30652.www3.hp.com/?jumpid=em_r329_CKM_18882&aoid=&rid=9E631BF1F5146DE2363F4BC64E581031&campaign_ID=|295740|18882
Hardware & Devices
Where to buy PC power cord in Korea
Does anyone living in Korea know where I can buy Schuko to IEC-60320 cords for my computers? I forgot to buy the cords in America even though I kept on reminding myself to buy it. Will I have to find a online retailer that ships internationally? Or will I have to search around in the streets of...
Hardware & Devices
Power cord on my desktop keeps melting.
Hi Guys, First time posting here so be kind. I have a Phillips desktop machine which up to a few weeks ago was running fine. 4 weeks back I was running a virus scan and left the machine alone only to return an hour later and find the machine off and the power cord at the back completely...
Hardware & Devices
Power cord question
Not sure if this is the right place to ask this. I just received my new HP computer today. The only problem with it is the wrong power cord. The adapter (brick like thing) plugs into the computer correctly, however the power cord from the adapter to the wall outlet is the wrong one (adapter has...
Hardware & Devices
Power Supply Cord Substitutes?
Let's say I have an applicance, like a computer speaker, microwave or vacuum cleaner, and one of the power cords for those items stopped working or I couldn't find them, and I believe I have other power cords in the house that are OF THE SAME TYPE. How do I confirm if I have another cord that...
General Discussion
