Windows 7: Num Lock, Caps Lock and Scroll Lock all lights up (not blinking)
26 Sep 2014   #1
jimkromann
MS Windows 7 Home Premium 64-bit
For some time now, i have been experiencing that my Num Lock, Caps Lock and Scroll Lock all lights up (not blinking) all at the same time, I tried to google it but i can not find any solutions or explanations for it.
Does anyone know if it is bad? and what is causing this?
I am having a wired keyboard with nothing fancy just a standard issue Logitech keyboard.
26 Sep 2014   #2
Berton
Can you toggle those functions off, one at a time? Sometimes restarting the computer will use the last state it was in, I'd fully shut down and pull the power cord from the computer and the keyboard cable then put them back and try again.
27 Sep 2014   #3
jimkromann
yea I can, right after posting this my keyboard "lit up" and when i hit one of the "lock" keys they all turn off again, after a while (3 mins or so) my keyboard stopped responding, so i turned off the pc, pulled the cable to my keyboard (its PS2 btw). then i took a brand new tooth brush and started brushing the socket on the cable, now its working again.
but I reckon this happening before, so i was thinking if those lights meant some kind of hardware faliure. ?
on screen caps lock on
I see lots of threads telling me how to disable the on screen CAPS LOCK ON message, but how and where do I ENABLE it? My Latitude has an led in the keyboard key, but there's always this hand of mine in the way.
General Discussion
Caps Lock/Num Lock, on screen pop up gone Gateway NV77
Good afternoon, I just did a clean install of 7 to fix errors with my laptop, and it fixed one, but not the other main issues, My caps lock, and number lock button on the keyboard don't have a light on it and the pop up that is supposed to pop up doesn't show up on screen. I figured by doing...
General Discussion
caps lock problems
hi i am having a problem with my acer laptop win7 x sixty 4 bit, i cannot get the '' at '' in like bill at gmail.com, i cannot get a six, an eight, a plus sign , or the question mark , maybe others . i run a paid for version of vipre anti virus, i disable it, downloaded malwarebytes, ran a full...
General Discussion
Typing in all Caps but Caps lock is disabled - Help
I'm a sloppy typist. I don't know if I hit some key combo or what but I was typing a letter in word pad and suddenly my typing is in all caps. I have used a reg file to disable my caps lock key on this laptop because it gets in my way - a long time ago. I know it cannot be the caps lock key. I do...
Software
Caps lock, num lock, scroll lock screen messages
Hi, how to disable Caps lock, num lock, scroll lock screen messages? I have desktop pc with two keyboards usb and bluetooth. Also TOSHIBA Bluetooth Stack software, but in device manager: keyboard > hid keyboard device both using microsoft drivers. And I dont have any software installed...
General Discussion
TrayStatus Displays Indicator of Num Lock, Caps Lock, S
Read The Rest At: TrayStatus Displays Indicator of Num Lock, Caps Lock, Scroll Lock Status and Hard Drive Read/Write Activity My Digital Life
News
