Windows 7: Monitor and restarting problems!!! Please help :(
13 Oct 2014   #1
kunoz
32 bit
My specs:
Amd A8 3780k processor
Asus F1A55-M motherboard
Mushkin silverline 2x4 gb RAM
640 gb hard drive western digital
so today, I was using my computer and suddenly my monitor turns off and says no input, also the lights on my gaming keyboard and mouse also turned off some reason... but the computer itself is still running. now when I try turn on the computer it would restart in around a minute and the monitor will say no input. mouse and keyboard work now. could this be the motherboard or something else? I'm currently trying to reinstall the OS (windows 7 home premium) But I can't so it due to it restarting and the monitor saying no input...
Thank you for your help!^^~
13 Oct 2014   #2
Ranger4
Have you checked to make sure the monitor has not become unplugged from the computer, more likely with an HDMI connection.
Also check that your graphics card is fully plugged in as well.
If this does not fix the problem it could be a PSU failure or the graphics card or the motherboard. It might be best to get it checked out professionally.
14 Oct 2014   #3
kunoz
32 bit
I think it's the motherboard..i am not sure..
If the monitor is not plugged in it would say no input the whole time.
2. I don't have a graphics card
And why would the PSU cause it to restart?
New monitor problems
hello Forum. I've just hooked up my new Samsung monitor, and I'm trying to have my screen use up all my screen estate, but there seems to be a problem towards the right hand side of my monitor, it has a 30 pixel gap. I've set the resolution to 1920 x 1080 but that's not working for me. Even...
General Discussion
Wireless Card problems after restarting from sleep mode
I have a very annoying problem with my laptop. I have a Dell XPS M1530 and I put Windows 7 professional on it. I have set it that every time I close the lid, the computer goes into sleep mode. When I open my lid, it goes onto the log in screen. Once I log in, it recconects to my router. It...
Network & Sharing
BSOD Restarting problems
Windows 7 x64 ? Brand new computer just bought on 2/11. Computer restarts every time I load my game. I've tried restoring the last known working settings, turning off automatic restart on system failure, and double checked the firewall. The zip with perfmon.html and the...
BSOD Help and Support
Problems with BSOD on Shutting Down or Restarting
Hi there Sorry for this being my first post, I couldn't find anywhere else to go, and I couldn't figure it out myself. I hope I cover everything here... Windows 7 Home Premium 32bit I think it came with my PC... I have uploaded my results and perfmon thing Anymore info you need, just ask :D ...
Dual Monitor problems - replacing 2nd Monitor
Hi, I had a two monitor setup Samsung 2333SW(DVI) + Philips 19B(VGA) running without any problems. I have now replaced the old Phillips with a Samsung P2770H, connecting the P2770 to DVI and switching the 2333SW to VGA(Analogue). Updated the drivers for both (rebooted) and when I look in...
Graphic Cards
Problems restarting the laptop
Hi everytime I use the restart on windows the laptop restarts but comes up with a black screen with no lights. The only thing that lights up is the power, wifi and hardisk light. However when I press shutdown and use my finger to power on the laptop it works. Laptop model is ML3108b (Gateway).
General Discussion
