Windows 7: Mouse moves but will not right or left click
14 Oct 2014   #1
Tornsoul
My mouse, Logitech g502 proteus core worked fine until today when my compter started up weird, it said something about my C: drive, I instinctively ignored it and let it run so I don't have the deatails , but anyway the computer boots up fine and I can right click or left click for about one or two seconds after startup but right after that I cant do anything except move the cursor, running in safe mode makes it work fine, ive tried uninstalling the mouse driver in safe mode, ive tried using system restore but that always says that it failed to restore, ive plugged the mouse into a laptop and that works fine, which is how I am writing this right now :/, any help with this would be greatly appreciated, thanks in advance.
14 Oct 2014   #2
Layback Bear
Windows 7 Pro. 64/SP-1
If it was my computer I would remove the mouse driver and then reboot and let Windows pickup the driver.
If your mouse works after that check Windows Updates for a updated driver.
16 Oct 2014   #3
Digerati
Windows 7 Profession 64-bit
"Instinctively" ignored it? Remind me never to get in a car with you!
I would try another mouse on that computer. And if wireless, I would replace the batteries.
I would also scan the computer for malware.
My mouse moves, but doesn't click?
Laptop Information: OS - Windows 7 Home Premium System Model - Hp Pavilion dv6 Notebook PC Version - Service Pack 1 No flash drives, mice, etc. are being used with this laptop Issue: When it started: Yesterday, I was replying back to my friend on skype when my mouse suddenly dragged one of...
Hardware & Devices
Mouse scroll and keyboard stop working until left click of mouse
After about 1 minute the mouse scroll and keyboard stop working until I left click mouse. Tool bar on browser also greys out but comes back after left click. Video and sound also are choppy. Not sure if this is related. Flash keeps crashing. Any ideas whats wrong? Windows 7 pro. Asus desktop. This...
General Discussion
help needed! mouse/touch pad can moves but can't click?
I've been having the problem of mouse/touch pad being able to move but somehow, i just can't click on anything with my laptop a few days ago. It just feels like everything is in the "not responding" state when using the mouse and also the touch pad but then everything seems just fine when I use my...
Performance & Maintenance
Laptop keyboard mouse:right click and left click functions reversal
Hi, I am after some help. My laptop has decided to reverse the right click and left click functions, ie: if I left click it now does not select but instead brings up a menu (which the right click button should and used to do!) I've tried holding down both buttons (as suggested by a friend) by this...
Hardware & Devices
Left mouse click dropdown
I seem to remember that there was a setting that I could change to prevent a drop-down from appearing whenever I clicked on an icon. Now I am presented with a drop-down that has "OPEN' as it's top item. Please tell me where the setting is.
General Discussion
Mouse pause on left click
I got a new mouse and replaced my logitech G5, i fully removed all those drivers and plugged in my new mouse which is a plug and play that has no drivers. It works fine its just when i left click or right click the cursor pauses in postion for a few miliseconds then will move with my motion. For...
Hardware & Devices
