Windows 7: False "Low Battery Alarm" with after-market battery - Dell Studio
18 Oct 2014   #1
ssimlai
Windows 7 Home Premium 32bit SP1
Hello,
Sorry for being away from posting on the forum since a long time, though I have been visiting the forum lot many times, without logging in - mainly through Google search. That shows how effective the website really is.
Since some time a very persistent error has been bothering me and I thought it best to come here and post the issue.
After my original battery for my Dell Studio 1555 32-bit computer died, I replaced batteries thrice, one after another (the computer is five years old).
The three replacement batteries were:
1. Dell - exact replacement 56 Wh
2. LB1 - matching specs but 48 Wh
3. Dell - exact replacement 56 Wh
Since the second replacement battery, the Low Battery Alarm has been disturbing me each time that:
1. The computer is restarted with the main power disconnected.
2. The main power jack is removed after a 100% charge.
3. The main power jack is removed anytime.
Since in the first place I never set this alarm manually, I am assuming there could either be a Dell specific registry issue with after-market batteries, though I don't understand why. Either way the irritant must go.
I checked Advanced Power Options under Power Scheme but found nothing that would give me a hint of what's wrong.
The alarm screenshot is attached.
Any help would be welcome.
False "Low Battery Alarm" with after-market battery - Dell Studio-low-battery-alarm.jpg
18 Oct 2014   #2
ss538
Windows 7 Enterprise
Rule out the OS and Drivers by downloading a Linux LiveCD and booting from that See if you get the same errors/alarms/warnings.
If you do it could be a faulty charging circuit in your laptop. Check with Dell and see if they have a battery calibration tool. Sometimes completely running the battery flat a couple of times does a "reset" kind of thing.
Sorry I can't think of anything else just now.
Reinstall driver "Microsoft ACPI Compliant Control Method Battery"
Hello all, I've spent a good few days trying everything the internet has thrown up to fix my mistake but nothing has worked. I shall list my attempts to fix subsequently. My problem is this: six days ago, I was using my laptop on its battery and I noticed that the battery icon in the...
Drivers
Dell Studio 1558 | battery doesnt charge even when it shows charging
Hi everyone, My name is Tarun. I have been facing an issue with my newly purchased battery. I did not use my laptop for an year or so because my battery was dead and i didn't even remove that dead battery from the laptop, it was kept inserted for an year. A few days ago I purchased a new...
General Discussion
Battery Not Being Charged ("plugged in, not charging")
So I've had this laptop (Toshiba Satellite C650-01V) since 2010 I think (I had it since I started university), and around early this month I've been having problems with my battery: it's not being charged. There's a message that says "plugged in, not charging", and I've tried multiple ways in...
Hardware & Devices
9 cell battery not living up to its "potential"
i have a hp pavilion dv7-core i5,17.3" screen and the battery is a 9 cell li-ion-93hr but it can't go past 3 hours on battery power even on power saver mode and discrete graphics turned off(always on intel HD graphics)..is this normal? i never game,just listening to music,watching movies and...
Hardware & Devices
"Internal battery" notices..what problems could a low battery cause?
Okay, so I've been having a few programs with my computer...this including slowness, poor wifi connections, and odd performance of wacom tablets. The problems with a tablet are described in more detail here-->...
Performance & Maintenance
Error "Consider Replacing Your Battery" Appears in Windows 7
Hello, i have the windows 7 battery problem i don't i know if it has been fixed yet but i've had my HP ProBook 4710s for about a 9 months now and about a month or 2 ago i saw this red cross on my battery icon and a error message when i click on the battery saying "There is a problem with your...
General Discussion
