Windows 7: SD card reader works but no "removal of hardware" sound or icon
12 Dec 2014   #1
mykemac
windows 7 64 Ultimate
I have an Asus CM1630 desktop running windows 7, 64 bit. SD card reader works, after adding drive letter, but there is no hardware removal or insertion tone and the is no icon to safely remove the SD card. The SD card works fine when placed in an USB adapter and plugged into the USB port - there is both the tone and the safe to remove... icon present.
For a while I could not get the Drive it(SD card reader) was in to show up. So I labeled it as Drive G: which was the original labeling and it shows up as a removable storage device. Any solutions out there?
12 Dec 2014   #2
pbcopter
Windows 7 Ultimate x64 SP1, Windows 8.1 Pro x64, Windows 10 Pro x64
If you were to use the safely remove hardware function on the card reader, it would uninstall the reader itself.
Right click on the Card drive letter in Explorer (My Computer) and select eject.
Grayed out Compact Flash Card in "Safely Remove Hardware" List
On a Windows 7 64 bit system, I've got a compact flash card set up like this: compact flash card > usb compact flash card reader > USB hub > usb port Previously, windows allowed me to safely remove both the card and reader. I unplugged and replugged some connections a while ago and since...
Hardware & Devices
Missing the " Safely Remove Hardware (USB) icon"
Not sure if this is a Windows or Toshiba issue. Ever since I installed a new (AT&T)wireless router and software, my taskbar icon arrangement was all messed up and the " Safely Remove Hardware (USB) icon" is missing in action! Is there any way other than doing a system restore, to capture the...
General Discussion
How to disable Systray icon "Safely remove hardware and eject media"?
In my Systray there is an icon "Safely remove hardware and eject media" which did not exist in WinXP. I guest this is for possible removing USB sticks from USB slots. However I should be able to remove USB sticks by just plugging them out. Per definition WinOS and hardware should be able...
General Discussion
Mod a 3.5" card reader drive so it has room inside for a 2.5" ssd?
I really love my case, but it doesn't have as many drive bays as it should. Currently I have: 5.25" blu-ray drive 3.5" SD/MMC/etc card reader drive 3.5" 1TB HDD 2.5" 60GB SSD I want t shoehorn in a second hard drive that's over 1TB, but I have no room, unless I tape the ssd to the bottom of...
PC Custom Builds and Overclocking
Show icon for "safely remove hardware"
I have set up several Windows 7 computers to always show the "Safely remove hardware" icon in the system tray, when a flash drive is installed. However, the Windows 7 Home edition I have just installed doesn't list that icon as an option when I click on customise. How can I get that option to...
General Discussion
Random "Hardware Removed" Sound
I installed RC and did all the updates today. Everythin going well. Drivers updated as well. Then problem came. As we all know that the "Hardware Removed" sound only plays when there's a hardware removed from your PC. But the problem is, no hardware is being removed from my lappy and the sound...
