Windows 7: Usb power surge
16 Dec 2014   #1
matts6887
Windows 7 ultimate 64-bit
Usb power surge
I keep getting the message one of the usb ports has malfunctioned and has exceeded its power limits or something like that. Ive never had a problem up until the past few days and now my usb ports on the top front of my case wont operate unless I reboot. Once i reboot they are fine for a short time; but then the same thing happens all over again. Now, even as much as a computer guy as i am ; this one has me stumped. Ive tried uninstalling and reinstalling the usb hubs, etc and that has done nothing. What should i do here?
16 Dec 2014   #2
matts6887
nevermind; solved my own problem. It appears I have a bad sync cable for my iphone. And that seems to have been causing the issue for some reason.
 Usb power surge
USB Port Stopped Working after Power Surge
Hi After a power surge on hub port when attaching a card reader to a front USB port one of my external hard drives disappeared. The drive works fine and is now on another USB port. The non functioning rear USB port has the following properties (image 1) and the location address looks...
Hardware & Devices
Network connections all disabled after power surge.
Recently my computer shut down due to a power surge, and I have rebooted it. The issue is that my computer no longer accepts any network connections. In the network and sharing center there isn't a map, and it just lists unknown, Beneath which it says "The dependency service or group failed to...
Network & Sharing
Power surge on USB hub port...
My system, see specs for details, started to popup this error message: "The usb device exceeded the power limit of its hub port" Clicking on the message brings up this window: There are two USB devices plugged in to the computer, keyboard and mouse in the USB 2.0 ports, when the...
Hardware & Devices
USB hub port power surge.
Well I just got a brand new medion computer (4GB ram, 1GB nvidia graphics card, dual core i5 3.0Ghz processor, etc) about 3-4 weeks ago and have had no problems till now. The problem is when i bought the computer i got a mouse and keyboard which worked with it till about 2 days ago. I have 3 USB...
Hardware & Devices
Power supply surge detected every reboot
Hi guys I get a power supply surge every time I reboot (its been like this for 3 days now) and I have to press f2 to load defaults and continue then it boots up fine. I want to know if I absolutely need a new power supply? or is there anything else I can do to resolve this. Thanks ...
Hardware & Devices
Not Reading HDs after power surge/loss
Greetings, Sometime during the day while I was @ work here was either a power surge or loss of power to my home yesterday. I think it was a loss of power. Now my computer is not able to start Windows. When I do the initial boot up it looks as though it is not finding my hard drives. I tired...
BSOD Help and Support
