Windows 7: Another USB Thumb Drive problem
09 Jan 2015   #1
squish8294
windows 7 ultimate 64 bit
I have a 1GB thumbstick that I'd like to recover. Diskpart can't clean it (CRC error), Windows can't format it, it DOES show up, and diskpart CAN see it. It has no partitions or volumes, and I can't chkdsk it, it's a raw format at the moment. Any ideas what to do? Ditching the drive is an option, but not preferred.
Edit: Seatools passed both short and long generic, have tried both erase options, both fail.
09 Jan 2015   #2
Pauly
Win7 Ultimate X64
Try the HP usb format tool, if that doesn't work I would ditch it
09 Jan 2015   #3
squish8294
Quote   Quote: Originally Posted by Pauly View Post
Error: Device media is write-protected
Edit: Got it to show a volume in diskpart
DISKPART> list disk
  Disk ###  Status         Size     Free     Dyn  Gpt
  Disk 0    Online          223 GB      0 B
  Disk 1    Online         1863 GB  1024 KB
  Disk 2    Online          465 GB      0 B
  Disk 3    Online          978 MB   977 MB
DISKPART> select disk 3
Disk 3 is now the selected disk.
DISKPART> list par
There are no partitions on this disk to show.
DISKPART> lis vol
  Volume ###  Ltr  Label        Fs     Type        Size     Status     Info
  Volume 0     G                       DVD-ROM         0 B  No Media
  Volume 1         System Rese  NTFS   Partition    100 MB  Healthy    System
  Volume 2     C   Local Disk   NTFS   Partition    223 GB  Healthy    Boot
  Volume 3     D   Local Disk   NTFS   Partition   1863 GB  Healthy    Pagefile
  Volume 4     E   System Rese  NTFS   Partition    100 MB  Healthy
  Volume 5     F                NTFS   Partition    465 GB  Healthy
  Volume 6     H                       Removable       0 B  Unusable
DISKPART> sel vol 6
Volume 6 is the selected volume.
DISKPART> clean
DiskPart has encountered an error: Data error (cyclic redundancy check).
See the System Event Log for more information.
DISKPART>
Edit: More data, and formatting, yay!
DISKPART> lis dis
DISKPART> sel dis 3
DISKPART> det dis
USB Flash Memory USB Device
Disk ID: 00000000
Type   : USB
Status : Online
Path   : 0
Target : 0
LUN ID : 0
Location Path : UNAVAILABLE
Current Read-only State : No
Read-only  : No
Boot Disk  : No
Pagefile Disk  : No
Hibernation File Disk  : No
Crashdump Disk  : No
Clustered Disk  : No
DISKPART> list volume
DISKPART> select volume 6
DISKPART> list partition
DISKPART> format
    0 percent completed
Virtual Disk Service error:
The cluster size is too big.
DISKPART> det vol
* Disk 3    Online          978 MB   977 MB
Read-only              : No
Hidden                 : No
No Default Drive Letter: No
Shadow Copy            : No
Offline                : No
BitLocker Encrypted    : No
Installable            : No
Volume Capacity        :     0 B
Volume Free Space      :     0 B
DISKPART> att disk clear readonly
Disk attributes cleared successfully.
DISKPART> det dis
Disk ID: 00000000
Type   : USB
Status : Online
Path   : 0
Target : 0
LUN ID : 0
Read-only  : No
Boot Disk  : No
Pagefile Disk  : No
Crashdump Disk  : No
Clustered Disk  : No
* Volume 6     H                       Removable       0 B  Unusable
DISKPART>
Thumb Drive
Are there any tools to repair thumb drives? I have a dive that will not format after I pulled it out without ejecting it.
Hardware & Devices
Problem with thumb drive after exiting virtual machine
The operating system on my desktop is Windows 7 Home Premium 64 bit. Today I installed VMware and then installed Windows XP in the virtual machine. I'm having a problem concerning my USB thumb drive. I am able to use the thumb drive in the guest machine and I think that I am disconnecting it when I...
Virtualization
USB Thumb Drive vs Portable HDD
Hi Everyone, I need your opinions on a purchase I'm planning to make soon. I'm in a bit of a fork as to what I'm going to get actually. A thumb drive would be more portable, so to speak rather than the portable HDD. An HDD would have way more space, however. I will mostly use this...
Hardware & Devices
Help may have messed up thumb drive.
FIXED Ok i have a 8g usb thumb drive. Tried the chrom os install on it and couldn't get it to load on a pc. So just decided to formate thumb drive AND NOW it only has 1 gig. I tried the Devise management and all i see it Devise has unallacated space...... Help....
General Discussion
thumb drive troubles
I am having trouble with my thumb drive. I can format it okay with FAT32, but not NTFS. Both Full and Quick format both end with "The format did not complete successfully". I have also tried from the command prompt and GParted. GParted did not return any errors, but Windows would not recognize it....
Hardware & Devices
partitioning thumb drive
How do you partition a thumb drive? Obviously, Windows cannot do it natively, but when I used GParted to partition it, it failed. I can created a 16GB partition on a 32GB drive, but I cannot for the life of me format the other half.
Hardware & Devices
