Enable test mode to solve USB problems?
Page 1 of 32 12311 ... LastLast
  1. Posts : 131
    Windows 7 Home Premium 64 bit
    My HP notebook computer suddenly lost function in all 4 usb ports (3 are usb3 and the usb2 disappeared entirely out of device manager). After trying to fix it myself and working for 2 hours with HP tech support, they still don't work. It's out of warranty so took to local repair shop. They say files are corrupted and it needs a clean install of Windows 7. I am an old, crabby woman living in the winter in Florida. All my software is in Michigan so I really don't want to do a clean install right now and lose all my software until I drive back up north in May. (No, my house in MI is locked up tight and there is no one who can get into my house with the snow they have been getting.) Tech guy said maybe a workaround would be to press F8 and enable test mode so the USB drivers would work. He said he would try it and call back. He hasn't called back, so who knows if it will work. Will it? If not, anyone have a better idea short of reinstalling windows? Would upgrading to windows 8 get my computer to recognize the drivers?
  2. Posts : 1,810
    Dual Boot: Windows 8.1 & Server 2012r2 VMs: Kali Linux, Backbox, Matriux, Windows 8.1
    Not sure how we escalated from USB ports not working to needing a new install because of file corruption. Thats quite a leap.
  3. Posts : 131
    What do you think?
    How would you solve it? I tried all the usual stuff like taking out the battery, uninstalling drivers in device manager, etc. The tech guy says its not a hardware issue.
  4. Posts : 6,458
    Try OPTION TWO of SFC /SCANNOW Command - System File Checker
    Copy C:\Windows\Logs\CBS\CBS.log to your Desktop (it is a protected file so you cannot attach the original)
    Attach the copy of the entire CBS.log to a new post.
    After seeing that output, I'd probably want to see a screen shot of the affected devices in Device Mgr.
    Do you have a fair sense of getting around Windows? Some of the things I'll suggest can get a bit technical.
  5. Posts : 131
    My computer is still in the shop. I probably will pick it up tomorrow and then can post the log info. I think I can get around Windows okay, although I'm not a computer geek by any means.
    I think I did run the system file checker and it didn't help. Will try it again when i get the computer back.
  6. Posts : 1,810
    I'm not saying I know the answer, we need you to have the PC and run some tests. In other words, we need more information. I just think bringing a PC into a shop for USB problems and telling you its file corruption needing new install is kind of a long leap. Maybe I'm wrong but I would think other things could/would be tried before telling you we need to start over.
  7. Posts : 6,292
    Ask the guys in the shop to try running Ubuntu or any other Linux distro on it. This way they can check to see if the USB ports are recognized in another operating system. If they are then you know it is a problem with Windows. If they are not it is a hardware problem.
    Ubuntu can be run from a USB stick without installing it on the hard drive, so it is a great, temporary tool to use in cases like yours.
  8. Posts : 13
    If it is a hardware issue , you won't boot Ubunto from the USB port.
  9. Posts : 131
    How do you use a usb stick when the usb ports don't work?
  10. Posts : 6,292
    Magic?
    Sorry. They can use a CD if it has an optical drive.
