#251
Opps, of course I meant TB - what a maroon I can be :)
The desktop versions of external drives are also portable - the main purposes are different.
A slim/portable drive is usually carried around wherever you go. It is storage for devices (laptops / game machines) that have no internal space for another drive.
A desktop version usually sits on your desk and is used for backup and cold storage (files that aren't needed all the time, but you don't want to look in a backup for them). This, of course, can be used for live data too, but that's a tricky data schema.
I think the desktop drives are a bit more reliable, only because of the form factor (bigger means more air, not only for cooling, but for the heads. Finally, the more you transport a drive, the more likely an error (bumps and bruises).
So if you're only going to transport the drive between MI and FL, then a desktop is what I suggest. If you want to carry the drive with you when you paint, then the slim/portable does the trick.
The best of both is to use the space on your laptop while you're out and about, and then copy ('backup') the new stuff over to the external drive on your desk when you get home. (every once in a while, you'll have to manage the data on your laptop - keep only what you want to have readily available). It sounds like a lot of work, but once you get a routine, it's not that bad.
Bill
