Windows 7: Lenovo won't turn on with battery, without battery turn on!
28 Jan 2015   #1
cikler
windows 7 ultimate x86
Hi!
I have lenovo ideapad g585gc 59-356202 e1-1200, dvdrw, 4gb, 500gb, radeon hd 7310m, 15.6" led, ....
Almost 2 years old.
Yesterday it didn't want to turn on, and then I took out the battery and try without it and then turned on and everything is ok.
So,
1. with battery (with or without ac power) won't turn on
2. without battery (of course, with ac power) turn on
The problem is evidently in the battery. I want to buy a new one, but how can I be sure that the battery is really dead?
29 Jan 2015   #2
TVeblen
There are no good practical ways the average owner can test the battery. You have to go on the evidence.
06 Feb 2015   #3
ICIT2LOL
To answer you in a few words the battery if let run flat a few times will wreck the internal composition of the lithium ion make up and the other thing is it may just be a rogue battery they are cheap enough now to just replace it.
It is best never to let the battery get below a third charge or at least quarter charge. In any case lithium ion batteries actually deteriorate from the day they are manufactured so even if never used can be become useless and I think I am correct in saying that can be as low as three years.
See towards the bottom of this article re life of them Lithium-ion battery - Wikipedia, the free encyclopedia
06 Feb 2015   #4
Solarstarshines
Quote   Quote: Originally Posted by cikler View Post
Hi!
Almost 2 years old.
So,
I know what the issue is lol it happens to all Lenovo's
I have a Lenovo A8 Tablet the only fix i know of is to press the power button hold it down for 10 seconds and repeat till it comes on
The best thing to do is keep it above 30% Battery and recharge you let it go all the way down it suffers also keep in mind most of the Lenovos use Intel CPU technology so that can be one of the issues power delivery
06 Feb 2015   #5
whs
Microsoft MVP
Only solution is to get a new battery - if that matters. This thing is dead. If the battery is connected the laptop is trying to get power from it. If this laptop is stationary, you may very well live without a battery.
06 Feb 2015   #6
ICIT2LOL
Thanks Solar basically what I was trying to tell the OP personally I think the battery is kaput and needs replacing..
PS and as whs has aid about living without it I use mine on mains power at all times except for very rare occasions.
LENOVO G550 Battery Replacement?
Hallo, ich benötige dringend einen neuen Aku für den LENOVO G550 und bin auf Hohe Qualität Akku Lenovo G550,Lenovo G550 Laptop Akku zu verkaufen bei akku-haus.com gestoßen. Die Preise fand ich sensationell, die Garantie liest sich gut - kann man dem trauen, hat schon jemand Erfahrungen mit denen...
Hardware & Devices
Lenovo laptop will not turn off at all...?
Hi guys, sorry to make two posts about the same thing, but I couldn't find a delete button for the other :S Anyway, I have been looking at a Lenovo Z570 laptop for somebody. It had a fresh install of windows and all drivers where installed and everything in that sense seems fine. The problem...
Hardware & Devices
Lenovo Battery Question
I just bought a Lenovo Ideapad Z570. It has two options for the battery charging. One is it charges the battery 100%. The other it only charges 50% and supposedly if you don't use your battery very often, it will extend the life of it. I don't use the battery very often, but would like to keep...
General Discussion
my laptop deosn't turn off in battery mode !!! :(``
hello everybody for few days I've facing this problem with my laptop when I plug it in to charging I can turn it off easily but in battery mode when I turn it off it still working in this step " Shutting down " and doesn't shutdown until I make long press to power button ...
General Discussion
Unable to see/turn on network, battery, volume, etc. icons
Hello, I recently noticed my network and battery icons have disappeared off my taskbar. When I tried to put them back, the check boxes in customize notification area were greyed out. I did a little research and people who had the same problem said to run "sfc /scannow" in command prompt. After...
General Discussion
Big Lenovo Battery Indicator Alternative?
The battery indicator in the taskbar on my Thinkpad Edge bar is huge, almost as wide as two application buttons. My old HP the indicator was much smaller. I know how to disable it, but is there a way to display a smaller battery indicator, like in the system tray?
General Discussion
