Windows 7: Pls. help me fix USB flash drive which does not boot anymore!
28 Feb 2015   #1
xcr
Windows 7 Home Premium 32 bit
I tried it on 3 separate machines, it is 1 USB drive; I want to fix that.
I can copy to and from files on it without error, default Windows system tools does not report an error (no bad sector, either), however it does not boot anymore.
It booted before.
- PendriveLinux.com FAT32 sytems
- Windows 7 ISO as NTFS
any help?
28 Feb 2015   #2
jumanji
Backup all the files on the pen drive, then format it with HP USB Disk storage Format Tool v2.2.3 HP USB Disk Storage Format Tool Download - Softpedia
That should cleanup your pendrive. Try creating your bootable pen drive after that.
Note: Right click on HPUSBDisk.exe and run as administrator.
04 Mar 2015   #3
xcr
Quote   Quote: Originally Posted by jumanji View Post
I did just that. HP USB Disk Storage Format Tool says: Device media is write-protected.
The stick works as before with Windows, however.
04 Mar 2015   #4
jumanji
I have seen this write-protected error thrown by the HP Tool. This happens when the device gets locked by some other process/program. Under these circumstances I plug-out the drive, reboot my computer, plug-in the drive and from the desktop short-cut HP Tool icon straightaway run it as administrator. I do not open anything else when the desktop appears. Straight to the HP tool from the desktop - not even my
"Computer" to check whether the drive appears in it . . Try it and see whether that helps.
If it does not help, try it on some other computer. For I would think some program on your computer is engaging the drive when Windows starts or as soon as the drive is plugged in.. I don't know what it is. May be some Linux which you have been experimenting. Another computer may not have it.
Can't boot from flash drive
Ok, so i'm trying to do a fresh install of windows but i can't get it to boot properly from flash drive. I've tried the microsoft usb tool and creating a uefi drive through rufus. I searched through bios endlessly and can't find CSM anywhere, i've also tried legacy on and off. Whenever i boot from...
Installation & Setup
USB flash drive does not recognize anymore by Windows
My hard drive portable did connect and functionnal on my laptop ASUS. Suddenly it is not recognized anymore by Windows, it is not displayed in the Computer window Explorer. The hard drive is not listed in Computer Management\Storage\Disk Management. At the beginning, the flash drive was...
Hardware & Devices
I can t boot from USB flash anymore
Hi all ! I used to create USB boots using the Program Ultra Iso and boot and install windows with my USB flash. but this time it isn t possible. when i choose to boot from USB, a black page comes, giving the message : start booting from usb device ...
Hardware & Devices
trying to boot from flash drive --- PLEASE HELP
I have had 1000 issues, but i'm going to try and narrow it down. it seems like everytime I try to fix a computer, nothing ever just does what it is supposed to. At the moment I created a boot drive out of my flash drive with windows 7. I set it to boot first on my bios and it loads but hangs...
Can't Boot from a 2GB USB flash drive
I have a problem booting from 2GB USB flash drives. I have no problem with 4 GB USBs. I've tried 3 different 2GB flash drives (2 brands Lexar, Toshiba) Examples include the USB bootable system repair and the Hirens boot USB. Both are under 500MB! Both are fine with 4GB USBs. The computer's...
Performance & Maintenance
Cant boot from Flash or DVD drive
So I'm trying to format my PC. I can't boot from my USB flash drive or my DVD. I've tried using my: Original Installation Disc which the PC is currently running (Vista x64 OEM) Windows 7 Technet Disc
