Windows 7: Installed new Laptop battery, 100% charge, but 25% wear level? Help
13 Apr 2015   #1
vid4763
windows 7 professional 64 bit Version 6.1.7601 Service Pack 1 Build 7601
Hello,
Thanks for visiting this thread and any advice you have.
The Laptop this is in regards to is a TOSHIBA A205-S7468 (not the C855 of my specs).
I'm finishing a few upgrades on this older, backup of mine (replaced screen, RAM upgrade, clean up) and the battery was in need of replacement. So, I purchased a new replacement on Ebay (I know, right) and it is working ok, but there has been a few red flags.
There was a brief episode with battery level and charge status, but I seemed to correct it by following some instructions on other threads here. It's now stable and 100%, HOWEVER, it reports it has 25% wear level and will only charge to 100% using 75% of it's capacity.
I've uninstalled (and then scanned for hardware changes) the Microsoft ACPI-Compliant Control Method Battery Driver (this seemed to straighten out battery level/charge status flags). Checked and made small recommended changes to power saving option (critical level, etc...). Drained it completely and recharged fully (per instructions).
Just wondering if anyone has any thoughts or advice as to why a new battery would be limited to 75% capacity (and be 100% fully charged)??
Here are screenshots:
Installed new Laptop battery, 100% charge, but 25% wear level? Help-battery-hwinfo.jpg   Installed new Laptop battery, 100% charge, but 25% wear level? Help-batterymon.jpg
13 Apr 2015   #2
TVeblen
Did you calibrate the battery as described in this article:
How to Calibrate Your Laptop
(Scroll down to "How to Manually Calibrate a Battery")
13 Apr 2015   #3
vid4763
@TVeblen
Thanks for replying!
read that article. Thought I did it right. Will re read for my accuracy and report back tomorrow.
15 Apr 2015   #4
vid4763
@TVeblen
I re ran the battery calibration instructions top the letter. same results. 25% wear level. As good as its gonna get and you get what you pay for on Ebay I expect.
Thanks for your help!
Replaced battery on laptop, Battery not taking charge.
Hi Guys, I have replaced the battery of my laptop after using it on AC supply for about year after my old battery died. I get this error message. "The AC power adapter type cannot be determined Battery may not charge. This problem might be solved by: Connect a Dell 65W AC adapter or...
Hardware & Devices
Laptop won't charge the battery
Hi guys! i recently purchased an used NC4400 laptop for work.... i chose that model because i have several years working with it and is one of the most rock solid laptops i ever have tried... but this time i think the seller sold me a defective one... the seller sold me this one...
Hardware & Devices
Battery wear level reached 42% in just one week. Am I cheated?
I use CPU-ID HW Monitor to monitor my laptop temperature and Battery Capacity. Since my earlier factory supplied Battery worn out. I bought a new battery from my nearby market. On First Day it showed 4% wear level. I didnt care much as its too less. I has been a week now. When I checked My Battery...
Hardware & Devices
How do I determine battery charge level in Win7?
Have a laptop with Win7 Pro installed. Is there a feature in this OS that lets me know my battery charge level when I using it? Thanks.
General Discussion
Asus laptop battery won't charge
Hi We have an ASUS K52Jr purchased in April last year. At the start of this year the hard drive packed it in while I was trying to download something on ITunes and it would not start up again. We were moving and so didn't get around to taking it in for a couple of months. Anyway, a couple...
Hardware & Devices
