Are all the fans working as they should?
Are their any name plates or stickers on the case?
Can you find your case online?
This information is helpful to understand the air flow of the case.
To clarify, is it the CPU temperature you're worried about? I'm looking at that CPU cooler and thinking that 66°C under load is probably to be expected with a cooler of that size. The fan isn't huge and it's running directly on top of the heatsink, even a cheap triple copper heatpipe cooler would improve your CPU temperatures I'd have thought.
The OP is worried about the motherboard temp at 68C and the front fans when turned up in speed it causes a BSOD.
My brain is getting confungalated.
We have two motherboard temp problems in two different threads by two different members. I think I have been getting things mixed up between the two.
That being said; motherboard temps should not be 68C if that is a correct reading. If this is a correct reading I'm thinking case air flow problems.
Because of the problems members have been having with HWMonitor in the last week or so I choose to use Speccy readings.
That picture DID prove that it wasn't the motherboard generating heat. The motherboard stays cool while the CPU is getting temperatures in excess of 66+ degrees. I DID download MSI afterburner as WindowsSniper suggested, and fans now run correctly when the CPU gets over 60 degrees.
I also took the following steps;
1. I moved the computer into a room that I can keep cool at all times
2. I moved the computer onto an elevated area to get maximum ventilation (it was originally under a desk)
3. I completely cleaned the inside of the rig out again.
I should be good to go for now!
Thanks everyone for the suggestions!
Rep for you all!
Glad things are working properly now.
I personally never put a computer tower in a enclosed space.
I only put a town on the flood if it is raised to it can get clean air.
Here is a little trick you might be able to use later. It all depends on the quality of your fans.
I run all my fans with full voltage which means they run at 100% max speed all the time. I run them off of a fan hub with direct connection to the power supply. If you choose the right fans this can be done without a lot of noise. If one chooses the wrong fans your computer will sound like a old prop air plain trying to take off with a heavy load.
My system in My System Specs has 14 fans at 100% and two water pumps and runs quite and very cool.
I might go with liquid cooling once I upgrade my graphics card, just so I can almost guarantee it will be kept cool. The only reason why I didn't get a lot of cooling from the start was because I was on a budget. Being my first build and all, I didn't want to bite off more than I could chew.
I fully understand. My cooling cost a lot of money. Just the damn fittings mount up quickly.
Building your own water cooling system takes a lot of home work first and for most. You don't want to buy parts that don't work with the other parts.
Building your own water cooling system is kind of like over clock.
You do it more because you want to rather than you need to.
