Windows 7: Best way to power two fans I wish to add to mini-PC
25 Apr 2015   #1
Fieldinator89
Windows 7 Ultimate 64-bit
I just purchased in many PC in a really cool metal case. when I got home I realized that system did not have any kind of fan and I figured this was alright because of its size. later I noticed that the system was very hot (touched w hand). I opened the case and noticed there was the ystem fan pins on the motherboard so I grabbed of the many that I had lying around indused sugru to attachet to the top inside of the case. so far it works really good and everything is fine. but also have these two smaller fans that fit perfectly into beside cutouts of the case and I think would look really cool and also provide further cooling. so I have both fans in the spa so I want them, but I'm not sure what the best route to take and it comes down to power in them neither of them has any plastic suck it on the end of the wires but both have just wires. what my best option would be to strip the wires back a little bit, and cut out little strip to Windows bare wire on the main sys fan's cables, and solder these to them? Would there be enough power provided for the 3 fans? Amy guidance and advice is greatly appreciated. Thank you!
25 Apr 2015   #2
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
I have no idea but if you look at your power supply and post the watts it has possibly someone might be able to assist
There should be a tag with what watts it is
Cheers.
25 Apr 2015   #3
Fieldinator89
It doesn't even have a traditional power supply man the entire computer case is just a little bit bigger than a power supply
25 Apr 2015   #4
Fieldinator89
25 Apr 2015   #5
carwiz
Windows 7 Pro-x64
All motherboard fan headers have a current limit based on the IC driver. For full size PCs, this is usually around 1A. So we need more information about the fans AND the "mini-PC". For the fans, are they 3-wire or 4-wire and what is the current draw? For the PC, what make and model?
For 4-wire fans, NEVER wire the tach lead in parallel with other fans on the same header. Use the tach lead on ONE fan and disconnect the tach lead for other fans on the same header. Tape off the unused lead to keep it from contacting any electronic components; Especially the motherboard.
25 Apr 2015   #6
Fieldinator89
https://youtu.be/slKrFhGT-Os
I just decided to make a video really quick so you can get a better idea of what's going on and what I'm talking about
25 Apr 2015   #7
DocBrown
Case fans can usually be connected in two ways. by an adapter to a molex power connector coming off of the main power supply (PSU). Or from a small 3 or 4 pin connection on the motherboard as carwiz posted above. Here are some typical fan cable connectors.
Best way to power two fans I wish to add to mini-PC-fan_ext_cable.jpg Best way to power two fans I wish to add to mini-PC-fan_y_connector.jpg
25 Apr 2015   #8
carwiz
Windows 7 Pro-x64
I was typing before I attached the image but 3-wire and 4-wire fans share the same pinout on 1-3. So when paralleling fans, both should follow the pin #3 restrictions. I corrected the previous post.
fans in or out?
hi i have a question about fans.my case is the corsair carbide 400r. there are 2 x120mm intake fans in the front ( which come with the pc), 1x 120mm fan in the back. and then extra room for 2x 120mm or 140mm fans on the top. and space for 2x 120mm or 140mm fans on the side, and 1x on the base...
PC Custom Builds and Overclocking
HP Mini 5103 Ethernet is automatically disabling on battery power mode
Hello guys. I have a little issue here. I've got a HP Mini 5103 netbook and I am using Ethernet connection for internet. The problem is that every time when I am unplugging the the charger from the laptop (meaning: laptop is working on battery power). I suppose it is some kind of power saving...
Hardware & Devices
4 fans, 3 normal headers + 1 "power fan" header. How to connect?
Hi guys. I received 3/4 of my new hardware yesterday. So, today, I decided to unpack my (huge) case to check out how will connect everything and also learn to "play" with it. So, the case has 4 fans (Lian-Li Lancool PC-K62) with 3 pins. According to my motherboard manual, there are 3 system...
Hey Fans
I have got a pc tower which only has a fan up at the top and at the back????????? The psu is up near the top as well. My mates used to have the back set as intake and the top as exhaust and got better temps, i tried it and the temps are in the 38% and hwen i ran a couple of programs i ened up...
help with fans
ok so i need input i have 4 fan connecters on my mother board CPU Fan - 4 pin Pwr Fan - 3 pin Sys Fan 1 - 3 pin - Un-used Sys Fan 2 - 4 pin its a gigabyte MB that comes with easytune which lets me keep CPU fan at 100% ok so this is the deal
Help with fans.
Have alook at the case pictures, can you please tell me which way i should have all the fans.??????????? A 120mm can be installed a front, 2 x 120 mm on the side and 140mm maximum on top of case. The case is NZXT Beta Evo Black Metal Edition (BEVO-001BK)
Hardware & Devices
