PC Case fan speed
Hi all,
Recently bought a HP Envy Phoenix. Specs:
CPU: i7 4790
GPU: GeForce GTX 770
2Tb HDD
128Gb SDD
16Gb RAM
When turning on the PC, all the fans ramp up, naturally, but the case fan used to stay on full speed all the time. I like a quiet PC, so it was mildly annoying. Now, I've never had a SSD in a rig before, so I was blown away with how quick it booted up. I can see why folks on these forums recommend them. Anyway, after searching online, I found a solution in that if I added a 5 second boot delay to BIOS, it would eliminate the fan-full-speed issue. And it did. Now the PC is fairly quiet with the case fan at normal speed and all is well. Temperatures remain easily within spec., even, say, when playing Far Cry 4 on ultra. All the fan speeds vary slightly as per normal under load. Does anyone know how this all works regarding the BIOS delay making everything run normal as regards the case fan speed? Was the PC booting up so fast that the fan speed simply just got "stuck" on full? Just curious. Thanks in advance.
