Windows 7: Crosshair Formula IV | Post State LED: CPU_LED red
07 Jun 2015   #1
lwrand
Hi everyone,
I really hope that the problem I'm about to share is bound with the PSU, but I'd like to read your opinions. Basically, my PC turned off suddenly, while it was running a game - I checked the LEDs on the motherboard and the "CPU_LED" was red, then I tried to reboot it, but the same led was still on. I started to think on the possible solutions so I left the PC there for almost 5 hours with the power supply disconnected.
When I came back to try, the led was not red anymore but, after like 45 seconds, the machine turned off again with the same red led on the "CPU_LED". Since I couldn't use my PC I took the opportunity to refresh the thermal paste on the CPU and clean the inside from the dust.
Now, I just tried to turn it on, and again, I could start the PC, and enter the BIOS, just to check temperatures and so on (My AMD Phenom II X6 1090T was running at 34 degree C, so nothing wrong here) but after like one minute, the PC went off with the same "CPU_LED" on.
Tomorrow I'll try to replace the PSU and see how it goes, but what're your thoughts ?
Many thanks,
/lwrand.
07 Jun 2015   #2
Mellon Head
See this thread for a possible explanation:
Crosshair IV Formula Red CPU LED on on motherboard stays lite and system wont post.
Do you have another CPU that you can try out? Also, do you have eight wires plugged in to the CPU 12V header, not four?
08 Jun 2015   #3
lwrand
Quote   Quote: Originally Posted by Mellon Head View Post
Thanks for your reply Mellon Head.
It was the PSU - After 4 years my CoolerMaster GX 750w passed away (and the huge amount of dust I found below, gave it the final strike).
System Freezes and not stable after installing Crosshair RAM?
I am getting a 30 second freeze after installing new RAM and sometimes a BSOD with memory code 0x00000f4 This is my system specs and its all new, i replaced everything within the past month so Im pretty sure its not a comopnant fairure but an installation failure. (yes I checked everything is...
PC Custom Builds and Overclocking
Blue Screens into a POST-failing state
I made my initial post in the General Discussion subforum, and I started it in hope that I would have more option the next day, and assess the situation from there. Brink did move it to this subforum, but I don't think he realised that I was just asking for pretty general information just to get my...
BSOD Help and Support
For Users of the Crosshair IV Formula Motherboards
For those of you that have the Crosshair IV Formula and are thinking of using a Creative Sound Card TAKE NOTE ! Turns out that if you ever install the X-Fi codecs that come on the installation disk with the Crosshair IV Formula motherboard, you will need to do an entire reformat of your...
BSOD Crosshair IV Extreme tcpip.sys
- x86 (32-bit) or x64 ?64bit - the original installed OS on the system? None - an OEM or full retail version? None - OEM = came pre-installed on system - Full Retail = you purchased it from retailer - What is the age of system (hardware)? PSU and GFX =1/2 years ? rest is 2 days - What is...
X-fi supreme with Asus Crosshair III
My problem seems to be a common one, yet most people have been able to resolve it where I have not. I have no sound. The only sound device I can see in device manager is a "high definition audio device" which I'm guessing is the x-fi card? I cannot find drivers for the x-fi supreme on the...
Crosshair III Formula RAID0 help
is there ANY compatible driver available for the 750SB ... of course I'm looking for drivers I can use to install 7 on my RAID0 striping array of two 150 gig VelociRaptors. I'm just trying to install the RC, not RTM for now. Please see my setup. Thanks, any help or a simple "no you can't...
Drivers
