Windows 7: Monitor randomly enters power save mode within 3 minutes of startup
14 Jun 2015   #1
cluelesshippo
Windows Home Premium 64 bit
Since today my custom built computer has been having issues with all the attached devices.
I left my computer on so that I could watch a stream on twitch.tv, I paused the stream and left my computer running without being used for about 3 hours ( the only thing running was google chrome and like 3 tabs). Upon coming home I saw that my computer had entered power saving mode, that is the lights were all yellow and the screen was black but I couldn't get it to wake up again. On top of this, my mouse and keyboard were also shut off (none of the LED's were lit on either device) and no sound was playing (I had left the stream unpaused the whole time). The only thing I could do was to hold down the power button of my computer and restart it like that. Once I restarted it, everything was working just fine; windows started and I could log in and do things for around 10 seconds to 3 minutes until my monitor "entered power saving mode" again, and this would happen every time I restarted my computer. I also took note that a few seconds after my monitor shut off, my keyboard, mouse, and sound would all stop working while the actual computer itself kept running (The fans were still on, the LEDs from the motherboard were still lit.)
I've looked through many threads on various forums and the only problem they address is the monitor shutting off randomly, but I haven't found a thread that deals with the other devices as well. Another issue is that if I do have to change some settings on my computer I only have like 30-90 seconds to do so once I log in.
This problem happened before as well when I had an i5 2600k processor and an EVGA P55 LE motherboard. I recently switched to my current motherboard and processor within the last month and no problems were had until today. I tried to see if swapping my 750W Corsair Power Supply for my old 500W Thermaltake Power Supply would fix anything, but it didn't.
I don't have another computer to use so this is infuriating. I can try to clarify whatever is unclear but I'm honestly not very computer-smart beyond putting hardware together.
15 Jun 2015   #2
GokAy
If it is happening on two different builds, I guess some software you are using?
Try Safe Mode.
And clean startup Troubleshoot Application Conflicts by Performing a Clean Startup
PC Randomly Enters Sleep Mode (Kernel Power Event 42)
Hello all, I've tried to troubleshoot this issue in which my laptop will enter sleep mode at random times. Strangely, it only happens when my computer is plugged in to the adapter. Looking in the Windows event logs showed that entering sleep mode was either caused by Event 37 (system is limited...
Hardware & Devices
monitor and power save mode
Sometimes, my monitor will not come out of power save mode even when I hit any keyboard key or hit a mouse button. Its been fine up til now. In order to get it to come out of power save mode; i have to constantly and completely power down then power up; and i dont want to keep doing that as i know...
Hardware & Devices
Monitor goes into power save mode while playing games. Forced restart.
As the title states. Just recently my monitor has been going into power save mode while playing certain games. Not all games but some games. Which I am trying to figure out what the problem is before I take it to the shop. If i can somehow fix this issue myself that would be great. Since I really...
General Discussion
During restart computer enters power saving mode
What could be causing the following situation- When restarting my computer (Windows 7 64bit) after the "starting windows" screen appears the screen will go dark and display "power saving mode". After about 60 seconds the computer will restart from the "starting windows" screen and complete the...
General Discussion
Windows 7 enters Power Save after 20 minutes
I have 64-bit Windows 7 Home Premium here on my home-built computer. The monitor enters power save mode exactly 20 minutes after I last touch the keyboard or mouse. When I am watching movies on my computer, it gets frustrating that I have to move the mouse every so often just so that I get 20 more...
General Discussion
after 4 minutes monitor wakes up from power saver mode
I set my screen saver to blank after 4 minutes and my monitor to power down after 5 minutes. After 4 minutes I hear the Windows seven default sound for log off (I think) and the screen powers up but the blank screen saver stays on. This only happens when I have a check mark by show the welcome...
General Discussion
