HDD LED on front of PC always on after 2nd drive disappears?
  1. Posts : 129
    So, I'll be using my pc like normal, and randomly my 2nd HDD will just drop off, and I'm not sure why. When it does, my PC's HDD LED is always on... I don't get it. I don't think the hard drive is bad nor do I think the cables are bad, what should I do? Should I try a cable switch? Should I clean the connections? I'm lost. I ran a HDD diagnostic and the test passed recently. This is what the HDD activity light looks like:
    It just stays always on like I said. If I reboot that solves the problem, but that's only a temporary fix.
    The drive is Western Digital 1TB Caviar Green drive, and the model is wdc_wd10eads-00m2b0. I've had the drive for quite awhile, and it hasn't really given me any problems until recently.
    Setting 'turn off the hard drives after' setting in power options to 'Never' doesn't solve the problem either.
  2. Posts : 1,686
    Download Download Hard Disk Sentinel Post a screen shot of the findings. This can be the sata cables, the sata socket on the motherboard or even the hard drive.
  3. Posts : 129
    Downloaded the trial version, will reboot and then scan, then will post an update with a screenshot.
  4. Posts : 129
    Well.. it's displaying good hdd health, except for this:
    HDD LED on front of PC always on after 2nd drive disappears?-problemshost.png
    My main drive isn't displaying any sort of message like that.
    Also I did some cable switching after shut down, and then booted back up once I switched.
  5. Posts : 129
    Ran a random seek test, it appears that it's ok. Here's a snip of that:
  6. Posts : 129
    The 2378 number has not gone up. Also it appears the total start/stop count on my main drive is less than the bigger one. The main drive only has a start/stop count of 192 while the problem drive had a 5,060 count. Does that mean anything?
    Main drive:
    Problem one:
    Here's a screenshot of the S.M.A.R.T tab of the problem drive:
  7. Posts : 13,576
    Make sure you have hard drive set to never sleep in the power options, yes it matters.
    I use HDS and I got that exact message on 1 of my 1 TB drives, guess what, that hard drive has been in a cardboard box for over a year, no longer used :)
    Hard Disk Sentinal is a good program.
    1 TB drives are cheap, just replace it.
  8. Posts : 129
    It is set to never sleep in power options. Also AddRam, what 1TB drive would you recommend if I were to replace it? I mean I guess I could but I'd have to transfer the data over to the new drive if that's the case, and there's a lot of data to transfer over.
  9. Posts : 5,656
    For what purpose you want the new drive?
    Backup - WD Green
    Speed/Silence - WD Blue
    Long Warranty/Speed - WD Black
    SSD would be best but I guess you need the space for data?
  10. Posts : 13,576
    Well, you don`t want to loose your data do you ?
    I recommend a Seagate Barracuda or a Western Digital Blue for storage.
