Windows 7: Help me reduce power usage on this PC
11 Jul 2015   #11
ish4d0w
Microsoft® Windows 7 Professional 64-bit
Thanks all. I'll see what I can do, but it's possible I'll only replace the case. It's hard to find parts for this one
12 Jul 2015   #12
Layback Bear
Windows 7 Pro. 64/SP-1
Old computer parts are like old car parts. The people who have them no they are hard to come by so they raise the price.
When you get done replacing all the things in the computer to become more green you could just turn off a lamp and save the same amount or more of energy.
Don't get confused with power supplies. As long as it's a quality power supply and has more than enough watts your good.
It can be a 1000W power supply and if the computer only request 200W that is all the power supply will put out. The difference is the 1000W power supply will do it with ease therefore less draw from the wall socket.
It is so small that I doubt that most users would have meters to read such small changes.
15 Jul 2015   #13
ish4d0w
Quote   Quote: Originally Posted by Layback Bear View Post
Thanks. I'll keep the old PC as it is, it is perfect for my grandparents
Oh, and great post on the power supplies - very informative, I was always unsure about power supplies So thanks !
15 Jul 2015   #14
Layback Bear
Your very welcome ish4d0w.
energy report using cmd
http://www.sevenforums.com/tutorials/4569-power-efficiency-diagnostics-report.html copy and past this in elevated command promt powercfg -energy -output %USERPROFILE%\Desktop\Energy_Report.html use this for a energy report which is saved to your desktop in html :D
Performance & Maintenance
how do i view an energy report?
Found this site... HEXUS.net - News :: How to use Windows 7 to diagnose system sleep problems : Page - 1/1, while searching for ways to fix my crashing to blue screen after bringing windows out of sleep problem, and it tells you how to generate an energy report that can diagnose windows sleep...
Amoung of energy used
I have my desktop computer on all day long running win7. I have it set so that the display turns off after 10 minutes on no activity. With the computer on but the display off, does anyone know about how much current would it be using compared to a 100 watt light bulb? Thanks ~Frank~
what do you know about Energy drink?
Hey everybody, what do you know about Energy drink? do you think it is injurious ? and why ? and what are benefits ?
Chillout Room
Energy saving, how to?
Hi, I'm using laptop. And I'm looking how to minimize power usage. I mean, minimal cpu power usage lowering voltage ant other on battery and AC.
General Discussion
Dark Energy May Not Exist At All
Source Interesting, yet it doesn't seem very likely to me. But, on the other hand, who knows....
Chillout Room
