Permission problems Hard Drive - standard options not visable
  1. Posts : 2
    windows 7 Home Premium 64bit
    Hi All
    I have an external HD has been working for for a few years but now get "access is denied"
    gone through the standard options on permissions.
    enclosed screen grab
    any ideas
    thanks Mike
    Attached Thumbnails Attached Thumbnails Permission problems Hard Drive - standard options not visable-pc-access.jpg
  2. Posts : 122
    Windows 10 LTSB 2016
    Are you saying that you are unable to access Local Disk F?
    What is the size and model of your ext. HDD?
  3. Posts : 5,656
    Post a screenshot of Disk Management as described in Disk Management - Post a Screen Capture Image please
  4. Posts : 2
    Hi thanks for taking the time to respond
    easwar2641993 Are you saying ...
    yes I get the error message mentioned, size is about 80% on 1TB
    GokAy= enclosed screen grab
    Attached Thumbnails Attached Thumbnails Permission problems Hard Drive - standard options not visable-em-hd-info.jpg
  5. Posts : 5,656
    Try plugging it into other ports.
    Do you need the data from this drive or have backups? Notice how the file format is empty for F.
    Tried restarting while external is still connected? Connect it to a USB 2 port and restart PC.
