Windows 7: Permission problems Hard Drive - standard options not visable
04 Jul 2015   #1
MikeBWD
windows 7 Home Premium 64bit
Hi All
I have an external HD has been working for for a few years but now get "access is denied"
gone through the standard options on permissions.
enclosed screen grab
any ideas
thanks Mike
04 Jul 2015   #2
easwar2641993
Desk: Win 7 SP1 HP 64BIT & Lap:Win 8.1 Pro 64BIT
Are you saying that you are unable to access Local Disk F?
What is the size and model of your ext. HDD?
04 Jul 2015   #3
GokAy
Post a screenshot of Disk Management as described in Disk Management - Post a Screen Capture Image please
05 Jul 2015   #4
MikeBWD
Hi thanks for taking the time to respond
easwar2641993 Are you saying ...
yes I get the error message mentioned, size is about 80% on 1TB
GokAy= enclosed screen grab
Permission problems Hard Drive - standard options not visable-em-hd-info.jpg
05 Jul 2015   #5
GokAy
Try plugging it into other ports.
Do you need the data from this drive or have backups? Notice how the file format is empty for F.
Tried restarting while external is still connected? Connect it to a USB 2 port and restart PC.
No Permission to Access Folders in Old Hard Drive
Hi, my hard drive got into some trouble yesterday and I haven't been able to load Windows. I tried the different options in recover, but nothing worked (it says couldn't repair the error.) I also tried loading in safe mode but it always got stuck at a certain .sys file. I know I can access...
General Discussion
Testing Standard SATA hard drive
I'm just wondering if a Standard SATA Hard drive would fit into my Acer Aspire v5? I want to test to see if the hard drive is working and don't have a USB converter cable for it at this time. I am not sure if it will fit into my other laptop.. & I didn't want to open it up if there is no need...
Hardware & Devices
I don't have permission for hard drive
I just had a new hard drive installed on my lap top. I do not have permission to open documents are word documents. These files include documents & pictures. When I try to open them, I'm denied. When I tried to transfer my pictures to Snap Fish, I was told that I need administrator's...
General Discussion
permission from administration to hard disk drive????
how to download any in HDD when something is like this.
General Discussion
Portable hard Drive - not automatically mounted and visable
I have two Identical hard drives . Both have been in use since I built computer Dec10. Now I plug them in and their not visable anymore? Their shown as a usb or scsi drive but no assigned drive letter or their "name". Their showing in the Disk manager and I found I had to manually tell it to...
Hardware & Devices
Hard drive permission messed up
I accidently changed the permission for my hard drive on Windows 7. I have C:\ and D:\ but after I altered the permisson of my D:\, now the access is denied. In the drive Properties under the Security tab, I ticked all the Deny boxes of the permission settings. I think the administrator was...
System Security
