Windows 7: These new parts compatible?
02 Aug 2015   #1
MrSH4RKYY
Windows 8.1 PRO
So I am going to be upgrading my system really soon
Already upgraded the GPU and the PSU,
I would love some of your expert advice on my pickings
New specs
CPU= i7 4790K
Motherboard= Gigabyte Z97X-Gaming 7 motherboard
I would also like to ask is the h90 a good cooler for the i7 I have picked?
And will this Case Zalman Z11 Plus Midi Tower Gaming Case
work with the Corsair h90 CPU cooler?
I picked out that case as it has 140mm support but on the specs it says = 120mm/140mm Fan Vent just making sure that it will fit
thanks for reading my post
02 Aug 2015   #2
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Not so sure the cpu cooler will fit anywhere but the front of the case :/
It's a 140mm and all you have is 120mm fans on the case,
Being the rear I guess is the most likely place for the cpu cooler but these radiators like to be intakes not exhausts but several people have used them as exhausts without issue
I prefer as a intake which would put the rad at the front of the case
The case does look wide enough on the front for a 140mm fan on it but I don't see on Newegg where it states there's enough room ? blue fan is 120mm and blue led,
But the top is the most common location for a radiator,
ZALMAN Z11 Plus Black Steel / Plastic ATX Mid Tower Computer Case - Newegg.com
Attachment 367863
So it would seem this cpu cooler would fit in 3 locations being it has 120mm fans
Corsair Hydro Series? H80i GT High Performance Water/Liquid CPU Cooler. 120mm - Newegg.com
I have no idea where the 2-80mm fans are located on the case :/
02 Aug 2015   #3
MrSH4RKYY
Windows 8.1 PRO
Hi thanks for the reply, was also asking on Overclockers fourms, and decided to change case and cooler, I am going to go with a H80i and another Case, just for price and fitting, thanks for the detailed reply, I am going to keep my options open in the next few weeks
02 Aug 2015   #4
ThrashZone
If you get a new case these would be better for the cpu your buying,
A 120mmx 240mm
Corsair Hydro Series? H100i GTX Extreme Performance Water/Liquid CPU Cooler. 240mm - Newegg.com
I have this one mounted on the front of my case which is a Corsair 450D mid tower,
The 120mmx240mm would fit best on the top of the 450D
Or 140mmx280mm on the front I did have to remove most of the extra hdd trays though I didn't need them anyway
Corsair Hydro Series H110i GT High Performance Water/Liquid CPU Cooler. 280mm - Newegg.com
New PC parts (need help)
Hi everyone, before I ask for some advice on getting new PC parts I know I have posted before about getting a new PC and picking out parts but I don't have the cash so I just need to use what I got :P. First I have a AMD Rig its ok specs right now. AMD FX4100 AMD Ghost 7850 GPU ASUS...
Hardware & Devices
Old computer needs new parts!
Hi guys I hope this is the right place to ask this! My girl's computer is getting old and could use some new parts. She has a budget of 400$ all for all. Here is her actual computer via Speccy. I'll let the gurus, or atleast, the guys that know this kind of stuff, help me find good...
PC Custom Builds and Overclocking
BSOD after getting new parts
I just got a new motherboard, graphics card, and memory. It has been bluescreening a lot and my games just stop working when I open them and play for some time. I re-installed the OS and updated all the drivers. I have also been moving the memory to different spots as well. I am still using my old...
BSOD Help and Support
Are all these parts compatible?
CPU Newegg.com - AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX Or Newegg.com - AMD Phenom II X6 1055T Thuban 2.8GHz 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDT55TFBGRBOX ...
Hardware & Devices
Where do you buy you PC parts?
Hi guys. I am from the UK and was just wondering when people on the 7 forums buy their bits and bobs? Cheers Rossy87
Chillout Room
