Windows 7: Tip for laptop users: battery condition, sleep problems
11 Nov 2009   #1
Kari
Lot of us Seven users have a laptop as a main computer. Todays new Dells, HP's, Sonys and Toshibas are so advanced and powerful you can do marvels with them.
The laptop's battery is a consumer product. Battery capacity will fade little by little, and you often notice a weakened capacity of the battery first when it does not last a lunch break surfing the Web.
If you are interested to see a full report of your laptop's barrery condition you can get it by running command prompt as an administrator and giving the command powercfg -energy. It creates a HTML file Energy-report.html.
Energy-report shows everything worth to know about your battery. For instance, it tells you if a program or device is preventing your laptop to sleep or hibernate:
Quote:
System Availability Requests:System Required Request
The device or driver has made a request to prevent the system from automatically entering sleep.
Requesting Driver Instance: HDAUDIO\FUNC_01&VEN_111D&DEV_76B2&SUBSYS_103C30F4&REV_1003\4&752edf3&0&0001
Requesting Driver Device: IDT High Definition Audio CODEC
USB Suspend:USB Device not Entering Suspend
The USB device did not enter the Suspend state. Processor power management may be prevented if a USB device does not enter the Suspend state when not in use.
Device Name: Generic USB Hub
Host Controller ID: PCI\VEN_8086&DEV_293A
Host Controller Location: PCI bus 0, device 29, function 7
Device ID: USB\VID_050D&PID_0237
Port Path: 2
Maybe the most valuable piece of information is found at the end of the report:
Quote:
Battery ID: Hewlett-Packard
Primary Manufacturer: Hewlett-Packard
Serial Number: ?
Chemistry:Lion
Long Term: 1
Design Capacity: 73440
Last Full Charge: 69926
Design capacity tells you the full capacity of your battery in milliampere-hours (mAh). Last full charge shows the mAh after last time it was full charged. These figures above tell me for example that my battery has 95% of it's desiged capacity which means it is still quite OK.
Kari
11 Nov 2009   #2
Dinesh
Windows® 8 Pro (64-bit)
11 Nov 2009   #3
Dinesh
BTW, Kari could you please tell me what do these figures mean?
Quote:
Battery:Battery Information
Battery ID Hewlett-PackardPrimary
Manufacturer Hewlett-Packard
Serial Number
Chemistry Lion
Long Term 1
Design Capacity 4752
Last Full Charge 4752
11 Nov 2009   #4
zx81
nice to know ;-)
Thanks!
11 Nov 2009   #5
Kari
Quote   Quote: Originally Posted by Dinesh View Post
Sorry, Brink. Was so keen to tell about this I forgot the main rule before posting; I did not search the forums to see if this was already told.
Serial Number
Chemistry Lion
Long Term 1
It means your battery is in mint condition. I'm just surprised how low mAh it has as designed capacity.
Kari
11 Nov 2009   #6
Dinesh
Quote   Quote: Originally Posted by Kari View Post
Serial Number
Chemistry Lion
Long Term 1
Kari
Even I was surprised about the Design capacity as compared to your laptop battery.
11 Nov 2009   #7
Kari
Yeah, can't figure your values out. Never seen so low mAh.
11 Nov 2009   #8
Dinesh
BTW, my laptop is 18 months old now.
13 Dec 2009   #9
Bud
How to get extended life from a laptop battery? Should you plug the AC in every chance you get? Or should I let the battery be cycled down and then re-charge it? Mine is a new HP laptop.
13 Dec 2009   #10
Kari
Quote   Quote: Originally Posted by Bud View Post
I connect my HP laptops (Pavilion and HDX series) always to mains if available. If I know I'm not going to need battery in a few days, I normally take it out when it is first fully charged.
This trick gives some 20-30 extra minutes because it cools the laptop down so it does not need so much energy for the fan.
Kari
Laptop not booting after the battery died during sleep mode.
Hello everyone. A few hours ago my computer was in sleep mode and unplugged when the battery died. Upon plugging it back in, I was met with an empty black screen. I turned it off by holding the power button, but the laptop refuses to boot now. Upon turning it on, I get the Toshiba start...
General Discussion
Upgraded my laptop with 8gb ram now have sleep problems
I have a toshiba satellite a660 upgraded the ram now when the computer gets woken from sleep it restarts it self is there a way to fix this
Software
Return Laptop To Factory Condition ?
hi all does anyone know the best way i can reset my alienware Mx18 laptop back to factory condition ? im not looking to set it from a earlier back up , i want to re set it back to brand new. hope someone can help thanx Matty
Performance & Maintenance
Let Laptop Battery Die, Having Logon Problems
So I have a stock Dell Inspiron 6400, and this weekend I left it on overnight without the power supply plugged in. I woke up to find the battery at nearly 0% and the desktop frozen, and was required to force shut it down. After rebooting, the computer ran disk checks, memory checks, and attempted...
BSOD Help and Support
Laptop goes to sleep if no battery but AC plugged in
I haven't verified this yet, but I wondered if it's a possible bug? I bought a Dell XPS M1330 over a year ago and it came preloaded with Vista Home Premium. Since I want to keep the batteries in good condition I run the laptop with no battery connected and AC plugged in whenever it sits on my...
General Discussion
