Windows 7: Can I connect PWM fan as a normal fan this way?
14 Aug 2015   #1
pcwin
Windows 7 Home Premium 64 Bit
This is my front fan connection that is the default stock fan that came with my CM 690 II Advanced casing
This is the new PWM fan I bought
Q1) Can I remove the old fan and connect the new PWM fan in this way? Do I always get maximum speed if I connect this way?
Q2) How to connect a PWM fan to act as a normal fan?
Q3) What is the point of using PWM? Isn't it better to use normal fan so it can work at maximum speed and your components will be cooler?
14 Aug 2015   #2
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
I believe so,
The yellow wire would go to I believe a support fan plug on the mother board.
PWM fans vs standard fans - Cases - Components
15 Aug 2015   #3
Mellon Head
To get a PWM fan to work as a normal fan, just use the red and black wires like in your picture. The fan will run at full speed, and you won't be able to vary the speed. The yellow wire might be the tachometer and would attach to a fan header on your motherboard to monitor fan speed. If the fan is running at full speed, there's no point in attaching that wire, unless you're curious.
still looses connect/doesn't connect - win 7 wireless home network
She keeps loosing connection, then has to wait until it decides it can connect again. She would wait about five minutes and then click on something and would gain access. http://www.sevenforums.com/network-sharing/324598-win-7-hp-computer-keeps-dropping-connect-won-t-reconnect.html the ...
Network & Sharing
Connect TV to PC with a direct connect Cat5 Cable
I have a large screen TV that I need to run PowerPoint presentations on, and maybe video. The IT department set up Cat5 from the PC to the TV, but I cannot get anything from the PC to display. I am trying this on two different computers. One is XP Pro, and the other is Win7 Pro. I would prefer...
Graphic Cards
Can't connect to internet "Windows was unable to connect to this netwo
Hello guys, I have just finished my very first computer build and am rather happy with most things. Unfortunately I am having problems connecting to the internet. I have a temporary dongle in place and because it's my only option for about a month I kinda need it to work. When I first...
Network & Sharing
4 fans, 3 normal headers + 1 "power fan" header. How to connect?
Hi guys. I received 3/4 of my new hardware yesterday. So, today, I decided to unpack my (huge) case to check out how will connect everything and also learn to "play" with it. So, the case has 4 fans (Lian-Li Lancool PC-K62) with 3 pins. According to my motherboard manual, there are 3 system...
PC Custom Builds and Overclocking
No apps connect to MY internet, but connect fine on my neighbours net?
I am trying to use limewire, couterstrike, bitcomet etc, but nothing apart from firefox/I.E. and windows live messenger can connect to MY internet. everything workd perfectly on my neighbours internet, when accessed from my own laptop. Please help me. Thanks.
Network & Sharing
cannot upload, connect to sites, connect to itunes, etc
HI :D So yeah, im new to this forum and hopefully somebody could help me solve this annoying problem. About a week ago, i went onto itunes and it said i couldnt connect to the store, saying that my network connection timed out. Well its been like this since then, and later i noticed, i also...
Network & Sharing
