Windows 7: System Unit Case Fans Power Requirments
26 Aug 2015   #1
rapstarrr91
Windows 7 x64 Home Premium
Processor: Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
Motherboard: BIOSTAR H81MHV3
RAM: 2x4GB 8GB Kingston Hyper X 1866 OC
Logical Disk: Kingston 120GB SSD
GPU: EVGA GeForce GTX 960 2GB 128bit
PSU: FSP HEXA 550w
I'm planning to hook up six 120mm Case Fans with LED Light.
I don't overclock so the questions is, will my PSU be able to supply enough if i add 6 fans?
26 Aug 2015   #2
ignatzatsonic
Fans use very little power--a watt or so.
You shouldn't have any problems due to the fans.
I have no idea if your power supply is good, bad, or indifferent, but if it has problems it won't be due to the fans.
Likewise, LEDs of the size you would find on a fan use very little power.
26 Aug 2015   #3
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Yep your gpu at full load is 400w
Although you don't have a lot of head room on a 550w psu as long as the mobo has that many connection you should be okay the system will adjust to temperature.
28 Aug 2015   #4
rapstarrr91
Thank you for the response. you guys have been very helpful
Bought new Power Supply Unit, won't power on. Did I buy the wrong one?
I have a Corsair CX430M PSU with 4 slots to connect in the back. CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com & bought a new Antec BP550 Plus PSU, which has 5 slots to connect to. Antec BP550 Plus ATX12V V2.2 80 PLUS Certified Modular...
PC Custom Builds and Overclocking
Case fans ..need help please
Ok I have a TA350DC M34709 fan but it has a 5 pin plug but only has 4 wires going into it : White / Red / Black /Blue Now I have a ASUS P5KPL-AM Motherboard but have connections from varous other fans, how do I get this one to fit the board As I used to have a NMB 3110GL-B4W-B59 80mm Fan...
Do I need case fans? Opinions on this system?
Building this system this weekend. Not much gaming, have gpu fan, cpu fan. Do I really need case fans? Case doesn't come with fans. I am old and hate excess noise! Thermaltake V2 ATX Mid Tower Case Corsair 500wt system builder psu GIGABYTE M68MT nForce 630a Socket AM3 Motherboard AMD Phenom...
Case Fans
I just installed a replacement 60mm exhaust fan (it is optional with this case), and was wondering, how long should a fan last if a system is being used say 24/7 (not powered down)? I bought two of them (so I have a spare), but does spending more moola equate to longer lasting (the two fans I...
Hardware & Devices
Case Fans
I am looking at getting a new case and have found a couple I like. One has alot of fans. There are two front, one side, one rear and two top fans, all 120 mm. This is the most I have seen on a case and am leaning toward it except it is a dull black color. I found another that is blue on the outside...
Case Fans...
Hello, I am replacing my case fans in my system tonight (2 of them sounded like garbage and the other 2 are just as old) My case is setup with 2 front fans at the bottom behind a filter. I am using these to bring air INTO the case. I then have 2 fans on the back of the case up slightly...
