Windows 7: Need Help With a Simple Problem
21 Sep 2015   #11
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Yep I'm not even sure we send China Plastic or PVC pellets anymore in exchange for computers.....
Used to be the only thing the usa exported besides oil/ fuel/ wheat.
Simple Test Problem
In the diagram below, the bottom drawing is the front view of this object, and the drawing on top is the top view of this object. Draw the side view or else draw a 3-D (isometric) drawing and post your results in this thread. http://www.pbase.com/craig_c/image/126474087/original.jpg
Chillout Room
Problem with my PCI simple communications controller driver
Hello.. I have a dell inspiron N5110 laptop . Now i'm using windows seven 64 bit , and I have a problem with PCI simple communications controller driver as shown in the attachment :( Is there any way to solve this problem ? Thanks a lot in advance :)
Drivers
Simple Network Share Problem
I have several computers on a wired home network, Win 7-64, no domains or anything fancy. All of the computers show the others in the Network section of Windows Explorer, except one computer (Rogue) can't see my main computer (Main). Main can see Rogue fine. I have tried everything I can find to...
Network & Sharing
Simple File Sharing Problem
I have a Windows 7 Professional PC and two laptops, one with XP Professional and a new one with Windows 7 Home Premium. There are only two files I share between the PC and the XP laptop, a music file and a photo file. These two are mapped on the XP laptop and have been for some time. ...
Network & Sharing
PCI simple communications controller problem
recently i have experienced wireless connectivity problems after a windows update, i cannot connect to any network. I discovered one of my networking drivers was faulty and after taking advice i reinstalled windows 7 completely. After completing this however i still could not connect and now i have...
Drivers
[PROBLEM][HELP] Cannot copy a simple low sized file
hi, i am trying to copy a folder with 4 items in it to my SD card. when i copied it, the green status green bar runs until it stops at about 80%, it kept on staying there for 15 minutes until an error popped up "error 0x80070079" as seen in the attachment. can anyone help me fix this problem?
BSOD Help and Support
