Windows 7: Need Help With a Simple Problem
19 Sep 2015   #1
bigmck
This problem sounds so easy I am ALMOST ashamed to ask it, but as you see, I am asking. == I have my laptop and I took the cover off the back. There are five screws in the cover which screw to the laptop. Got the picture I hope. I was going to replace the screws as the area where the Phillips Screwdriver fits is wearing. I got the back off but the screws that are in the hole of the cover seem to stay there no matter how much I unscrew. Have any of you run across a problem like this before? I hope one of you has a "Secret Hint" to get the screws out of the cover. Thanks,
19 Sep 2015   #2
Brink
64-bit Windows 10 Pro
Hello Jim,
You migh turn the laptop where the screw heads are facing downwards, and gently shake the laptop a bit to see if the screws may fall out then.
19 Sep 2015   #3
bigmck
Yes, I have the cover off and the screws are still in the cover. I have unscrewed a bunch (the screws are turning) but they don't seem to come out of the hole. I just thought I might be overlooking a simple way to get them out of the cover.
19 Sep 2015   #4
Layback Bear
Windows 7 Pro. 64/SP-1
Put pressure on the pointed end of the screw and at the same time unscrew it.
At the present time the screw is riding on the clean shank of the screw and you need to start the threaded part of the screw to back it out.
20 Sep 2015   #5
bigmck
I will give that a try and I appreciate the reply.
20 Sep 2015   #6
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Hi
Yes they are designed that way so people do not loose them
20 Sep 2015   #7
bigmck
These screws are made out of a PVC type material instead of metal. I am not quite sure what the thinking was there. They even recommend changing them after a few openings because the Philips-Hole wears out. I am afraid the things will strip out on me. I guess I should leave well enough alone and not open it until I need to. Thanks to everyone for the assistance.
20 Sep 2015   #8
ThrashZone
Mine seem like metal :/
I suppose 6-7 years ago assembly standards were different ?
21 Sep 2015   #9
bigmck
Quote   Quote: Originally Posted by ThrashZone View Post
Mine is fairly new, from 2011. I just don't understand putting in PVC screws
21 Sep 2015   #10
Layback Bear
PVC screws are cheaper.
Simple Test Problem
In the diagram below, the bottom drawing is the front view of this object, and the drawing on top is the top view of this object. Draw the side view or else draw a 3-D (isometric) drawing and post your results in this thread. http://www.pbase.com/craig_c/image/126474087/original.jpg
Chillout Room
Problem with my PCI simple communications controller driver
Hello.. I have a dell inspiron N5110 laptop . Now i'm using windows seven 64 bit , and I have a problem with PCI simple communications controller driver as shown in the attachment :( Is there any way to solve this problem ? Thanks a lot in advance :)
Drivers
Simple Network Share Problem
I have several computers on a wired home network, Win 7-64, no domains or anything fancy. All of the computers show the others in the Network section of Windows Explorer, except one computer (Rogue) can't see my main computer (Main). Main can see Rogue fine. I have tried everything I can find to...
Network & Sharing
Simple File Sharing Problem
I have a Windows 7 Professional PC and two laptops, one with XP Professional and a new one with Windows 7 Home Premium. There are only two files I share between the PC and the XP laptop, a music file and a photo file. These two are mapped on the XP laptop and have been for some time. ...
Network & Sharing
PCI simple communications controller problem
recently i have experienced wireless connectivity problems after a windows update, i cannot connect to any network. I discovered one of my networking drivers was faulty and after taking advice i reinstalled windows 7 completely. After completing this however i still could not connect and now i have...
Drivers
[PROBLEM][HELP] Cannot copy a simple low sized file
hi, i am trying to copy a folder with 4 items in it to my SD card. when i copied it, the green status green bar runs until it stops at about 80%, it kept on staying there for 15 minutes until an error popped up "error 0x80070079" as seen in the attachment. can anyone help me fix this problem?
BSOD Help and Support
