USB High-Low sound every few minutes
brocksamson
12:27 PM
I keep getting the USB disconnect sound and my mouse will freeze every few minutes. I have tried 1. switching the mouses usb port. 2. reformatting the computer. 3. unplugging the USB hubs from the MOBO. the problem isnt that bad right now and probably happens every 15 minutes now but before i reformatted it was happening every 5 seconds and i couldnt even trouble shoot because it took me 5 minutes to get the mouse cursor across the screen. It might also be worth mentioning that the problem got really bad after installing and playing L4D2.
I am using windows 7 64 bit
Thank you in advance for your help.
Windows 7 64biti7 2.88 ghz4 gigs DDR3Geforce 8800 GTS
Windows 7 64bit
i7 2.88 ghz
MSI P55-GD65
4 gigs DDR3
Geforce 8800 GTS
N/A
27 KDS
300 gig western digital
brocksamson, welcome to the forums
Is it a wired mouse?
Do you have the latest drivers? Check on Device manager for any device with a yellow exclamation mark by it
Tks
Windows 7 x64 finally!AMD Athlon II X2 240OCZ Platinum 4GB DDR2 1066 (will not work pas...MSI R4670-MD1G Radeon HD 4670 1GB 128-bit GDDR3
Wally, Innc.
Biostar TA790GX XE
OCZ Platinum 4GB DDR2 1066 (will not work past 800MHz)
ATI High Definition Audio Device Realtek ALC888
HP w19e
Western Digital Caviar Green WD5000AADS 500GB SATA
Western Digital Caviar Blue WD5000AAKS 500GB SATA
Athena Power Micro ATX 400W
HEC 6T 6T10BB Black MicroATX Mini Tower
stock
wired, many keys
HP wireless, 2 buttons, 1 wheel
DSL 2Mb (recently getting 1.65M!)
first off thank you for such a quick reply.
It is a wired Logitech mouse. There is nothing on device manager with an exclamation point on it. as for the drivers its a fairly old mouse so im not sure the drivers would still be up. however, i have tried bringing the mouse to a friends house who also runs window 7 64 bit and at least for the 30 minutes i had it plugged in there were no problems
Windows 7 64bit
i7 2.88 ghz
MSI P55-GD65
4 gigs DDR3
Geforce 8800 GTS
N/A
27 KDS
Do you have many USB devices connected at the same time? Maybe it is a power problem. Try disconneting other devices and experimenting with the mouse. What power supply do you have? On a second thought, your i7-860 is only 95W, so it woudl have to be a wimpy power supply to be presenting problems. But it is worth checking
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
I remembered how to see if it is a power problem. Right click My computer, Device Manager, Universal Serial Bus controller, right click USB root hub, click on Power tab and see how much power every device is using. If it is close to the max, that might be the problem.
Also, can it be the cables in your mouse are damaged? Try the opposite experience, plug another mouse to the same port and see if you have ht esame problem
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
yeah im gonna see if my buddies new wireless mouse works cause if it does im about due for a mouse upgrade anyways so rather than spend all this time trying to fix it i can just do that as for the power usage it says i need 0mA for the root hubs and i have 500 mA available.
Windows 7 64bit
i7 2.88 ghz
MSI P55-GD65
4 gigs DDR3
Geforce 8800 GTS
N/A
27 KDS
If the mouse is connected and it is showiung 0mA, then uyuo haev a cable problem, it should be drawing some current
Let me know how it goes
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
ok i found the mouse under generic usb hub its drawing 98 mA i found the drivers for it but they dont have windows 7 drivers for it should i get vista drivers? i know windows seven is on the same architecture as vista.
Windows 7 64bit
i7 2.88 ghz
MSI P55-GD65
4 gigs DDR3
Geforce 8800 GTS
N/A
27 KDS
They usually work. Make sure they are for 64 bits as well.
Indeed, 98mA is not a problem, but what about everything else? Do you have several devices attached?
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
yeah everything looks to have enough power. i changed the usb slot and its been maybe 45 minutes without a problem ill probably stop trying to fix it for now and not post again until i have tried my buddies wireless mouse. Thanks again for sticking through this with me i have ruled out alot of potential problems because of it.
Windows 7 64bit
i7 2.88 ghz
MSI P55-GD65
4 gigs DDR3
Geforce 8800 GTS
N/A
27 KDS
Thank you, if you can let us know what the resolution is when you find it, it will also help others
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
fixed
OK, i figured it out. i did two things simultaniously but i havent had the problem since i did. the first thing is i cleaned out the mouse sensor. Not sure if it helped but what the heck. the second thing which i think actually fixed the problem is this. I went device manager (if you dont know how to get to it you can search for it) then i went to my Universal serial bus controllers. From here right click on the different contorllers and go to properties till you find what hub your mouse is under (mine was under generic usb hub). then go to the far right tab under power management. Under this a box will be checked that sets windows to turn off the mouse to save power. I unchecked this box and since then i have yet to have the problem. Hope this helps!
Windows 7 64bit
i7 2.88 ghz
MSI P55-GD65
4 gigs DDR3
Geforce 8800 GTS
N/A
27 KDS
Thanks for sharing the results. I never thought of that, I woudln't think it would be turning it on and off all the time.
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
