Shouldn't really need to find or look for the clipboard, it only stores one thing at a time anyway, just right click> paste or Ctrl+V.
That is an interesting tidbit though.
Yep that is what I did but nothing showed maybe it is the board dying?? Anyway I ma away form my place for a bit so will have to try next time I am there.
Can you be more specific? What didn't show????Yep that is what I did but nothing showed
> The the tool not run?
> Tool ran but nothing listed under Disk Drives you could select?
> You selected a Disk but then didn't see a Cliboard button??
> p.s. point of note: You must select any one Disk devices, and not the Disk category if that's what you did
> You won't see anything happen when you click Clipboard button. You only see resulting information when you paste into something (like pasting back into your post)
Can you post the screen shot9s0 and explain what didn't work?
1) I'm curious as no one has ever reported that user problem before so would like more specifics
2) If necessary, we can also collect the information I want manually)
If you could try that tool again per above as i've never had a problem with it before (so am curious as to where you find a problem)
But to save time (and your nerves in trying to fix this problem!) here's alternate instruction to manually provide the starting data i want
- Right click on any disk drive you see in Device Manager, select Properties then the Details tab
- Use the pull down menu to carefully look if any entry exists for Class upper filters and/or Class lower filter (see snapshot below) For each if found, you can Ctl-A to select all the display info then paste that info for each into next post. Or simply take snapshot(s) if easier
- Now go to the Driver tab. Click the Driver Details button. Provide a snapshot of the Driver File Details window that appears
Ok I will try that when I next have access to the machine. IT is very frustrating though because I have several USB outlets on the thing and not one of them work with a stick/s yet the KB and mouse no problems
Sorry for very late replymate but don't get back to my place very often. Attached are pics of the drives and results they may not be in order .
Also at desktop screen on the Password appears and is entered it pops up this ini message??
Now I notice the second drive the spinner has that PartMnr listed in the filters.
Have had problems with this Ivy machine for a long time now
Bingo! I've fixed this problem before. It's the Samsung Rapid Mode filter. Try turning off Rapid Mode. Verify the Samsung lower filter is no longer listed. Try your usb drives again. Hope that works for you too!
This device cannot start. (Code 10)
/* EDIT */
Some have also uninstalled then reinstalled Samsung magician to fix the problem. Either approach seems to have worked in the past
Thanks CG mate I shall give it a whirl when I am next at my place (I live with my partner now).
Perhaps it has been causing the other problems too and I shall reinstall the Magician too - I have used it to do things with the drive nothing over the top but again perhaps it has got corrupted.
Who would even think that would cause my board USB's to fail?? it simply makes no sense - to me
I am back there this weekend I will update you.
