Windows 7: Bluetooth Audio Input Device Mic Volume won't stay where I set it.
06 Nov 2015   #1
lorne17
Windows 7 Professional x64
Hello there,
I have a bluetooth headset I bought to use with Comcast Softphone VOIP software on my computer. I got bluetooth to pair and connect fine. However everyone says it sounds like I'm in a factory. I'm in an office where typing and the printer are the loudest things near me!
So the mic is way to high. I went to "Manage Audio Devices" and went to recording tab, then double clicked my "Bluetooth Audio Input Device". Once there I wen to the "Levels" tab and changed teh volume to 12. That was the sweetspot that the person on the call said they can hear me well and not a lot of background noise. But as I continue talking the volume keeps jumping up and ends up around 30-50. Which then everyone says the factory sounds are back!
How do I get this volume to lock? It stays at 12 when I'm not on a call using the mic, but then I make a call, use the mic and it jumps up again. I have to keep muting my headset while on a call!
Can anyone help me troubleshoot this? I also did the microphone setup and that didn't help any. I went to "Setup a Microphone Wizard" and used Headset Microphone and spoke the sample sentence to set it up. When doing that I watch the input volume go to 18. Then I make a test call and it jumps back up to 30! WHYYYYY!?!?!? I already returned one headset thinking it was shoddy. But got a Plantronics one (highest rated on Amazon) and it is the same case!
Thanks in advance for your help.
06 Nov 2015   #2
Lava King
Look in your Comcast Softphone software settings for "Automatically adjust microphone" or something similar. Make sure it is turned off.
Have you used the headset with any other software (Skype, Discord, Zoom, etc.)? If it works normally elsewhere, then the problem would have to be in the Comcast software.
HTH
09 Nov 2015   #3
lorne17
SWEET! There's a setting called "Automatically Gain Control". That's the part that screws it up. So I unchecked that and it works like a charm!
Thanks for the help Lava King.
Lorne
Microphone No Audio Input Device Found
Hi. I want to try using my microphone when I am playing some games and doing other things but I just noticed that the microphone device cannot be detected. Just so you know, I am using a Gaming headset that has a built-in microphone in it so I am pretty sure that the microphone's with it. Also, I'm...
No audio input device problems
I recently purchased a new pc laptop, but I had a problem, I tried to set up my new headset but I got the "no audio input device found" I spent about two hours searching what the problem could be, I needed to update my driver, after I updated my driver to realtex I got the "you just plugged in a...
No audio input device found
Hey everyone, I am trying to get my mic to work, but when I hit "set up microphone" it says "No audio input device found". I have a High Definition Audio Device installed and the sound works fine. However, under the "recording" tab in Sound it says there are no audio devices installed and the...
Problem with sound device with audio input.
I got a problem with my audio system. I have got two sound devices for my PC and one of them is not working. I have got one Philips Subwoofer which works fine, it has got a audio input. Also I have got a Philips Tv-flatscreen used as main monitor which is connected with a HDMI-cable. Ever since...
No Audio INPUT Device
I have an Asus P6T motherboard with Realtek ALC1200 on board audio and Windows 7 64 bit OS, DirectX 10, Audio Driver version 6.0.1.5859. The sound works normally for all audio functions. I installed Nero and went to use the Wave Editor application to record a song from the web and got the...
How do i fix my multimedia audio controller & pci input device driver?
My mobo is foxconn G31MV-K, Socket 775 Processor : Intel(R) Pentium(R) Dual CPU E2180 @2.00GHz @2.00Ghz RAM : 1.00 GB OS : Windows 7 Ultimate 32-bit Audio: 5.1 HD audio by Realtek® ALC662-GR The main problem is the multimedia audio controller & pci input device in the device manager always...
