Might be a unique hard drive problem
Angus
10:36 AM
I read about the other hard drive issues about them not being detected, and my problem is different. My 1TB (where I keep all my games etc) shows up on restart as my F drive (yes, it does have an assigned letter). However, at random times, the drive will just disappear and all the shortcuts into that drive will be invalid. The drive doesn't show up on the add hardware search, the device manager, nothing at all. However, when I restart, the drive is back and works fine.
Both drives are SATA, run off the same strand from my PSU (different connectors of course), and worked without a hitch when I had the same setup with Vista.
For what it's worth, when I switched to 7, I wiped and repartitioned my C drive and left the F drive (the one in question) the way it was.
Windows 7AMD X2 6000+3 gigs DDR2nvidia 9800 GTX+
AMD X2 6000+
Asus M2N SLi
3 gigs DDR2
nvidia 9800 GTX+
Audigy Platinum
24" LCD
250 gig system drive
1 TB info drive
Antec Earthwatts 650w
Sounds like you have a faulty chipset driver...install the most current chipset drivers and give it another whirl
Windows 7 Home Premium x64 - Mac OS X 10.6.4 x64Intel Core 2 Duo T9300 2.5 GHz4GB Kingston DDR2-800NVIDIA Geforce 8600M GT (512MB Model)
JFT02
WUXGA Standard Laptop Display
1680*1050
Standard Laptop Power Supply
Standard Laptop Case
Standard Laptop Cooling
Synaptics Touchpad
If i had a faulty chipset why did the problem start right after windows 7 install and never happening before that?
AMD X2 6000+
Asus M2N SLi
3 gigs DDR2
nvidia 9800 GTX+
Audigy Platinum
24" LCD
1 TB info drive
Did you ever install a chipset driver?
JFT02
1680*1050
Synaptics Touchpad
No, I haven't. I installed some updates today (first time since install I think) and I haven't had the problem, where would I check my chipset drivers? through Asus or AMD?
AMD X2 6000+
Asus M2N SLi
3 gigs DDR2
nvidia 9800 GTX+
Audigy Platinum
24" LCD
1 TB info drive
yes it would be a good idea to check for the latest chipset drivers.
windows 7 64 bitintel core i5 3.30GHz Quad Core6gbAMD RADEON HD 6450 1GB Dedicated
HP Pavilion p6795a
windows 7 64 bit
HP
6gb
ATI HIGH DEFINITION SOUND
LG
16:9 Hd
1TB
Fan
Wireless
HP wireless keyboard and mouse
fast enough
Beast Of A Machine!
ok, I updated to the newest BIOS drivers I could. The problem persisted. I then opened my box and used a different SATA cable strand to power the hard drive, so each has it's own. hope this works.
AMD X2 6000+
Asus M2N SLi
3 gigs DDR2
nvidia 9800 GTX+
Audigy Platinum
24" LCD
1 TB info drive
