Windows 7: USB 3.0 port does not recognize flashdrive + another problem (explaine
17 Dec 2015   #1
Steampunk7
the title says it. I installed win7 on my new configuration, downloaded latest drivers from ASUS website, then downloaded SP1 and more than 230 (!) important updates via WU.
There are two 2.0 and two 3.0 ports on my Fractal design R5 front panel. One of the two USB 3.0 ports is not working, meaning that it does not recognize my San Disk 32GB 3.0 pen drive (though Device Manager as you can see, does recognize it). Even when I plug it on the other (working) 3.0 port I got generic notification that it can perform faster if I connect it to 3.0 port (!). Obviously, something is not working properly. I checked the USB drivers one by one via Device manager and it says that the drivers are up to date.
Then I checked Device and printers via Control Panel and I noticed yellow triangle notification on my PC (see attach.) I checked Other device on DM which also has yellow triangle notification and it says that Windows can not find driver for that unknown device.
Any clue to what might cause this..?
USB 3.0 port does not recognize flashdrive + another problem (explaine-13.jpg
USB 3.0 port does not recognize flashdrive + another problem (explaine-12.jpg
17 Dec 2015   #2
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
No telling if this is true or not but a few reviews say this model does not like win-7 :/
SanDisk Extreme 32GB USB 3.0 Flash Drive Model SDCZ80-032G-A46 - Newegg.com
20 Dec 2015   #3
Steampunk7
It is beyond help, obviously :/
20 Dec 2015   #4
ThrashZone
Well I have a pny usb 3 and it works well so it's likely just the manufacture that is lazy
A USB2.0 Port Doesn't Recognize Devices Plugged In Anymore
A few days ago, a friend of mine rammed his office chair to the side of my USB stick breaking it and additionally caused a physical trauma the USB port it was plugged in (on the front panel). Left port is not recognizing devices EDIT: Gallery of assembly: https://imgur.com/a/WmjRB ...
Hardware & Devices
Problem transferring data via flashdrive
I am in the process of moving to a different computer. The one I had before is a laptop ASUS with Windows 7 Ultimate 32 bit. The one I'm transferring to is a Windows 7 Ultimate 64 bit. I copied a very large folder onto a 32 gig flashdrive, put it in the new computer & it did not show. Other...
Hardware & Devices
in 32-bit Windows 7, DOS program does not recognize COM port. Help nee
I'm running an ancient DOS program in 32-bit WIN 7. Program works fine except when I need to communicate with a scanner connected to a virtual COM port through a COM to USB adapter. Any suggstions would be greatly appreciated.
General Discussion
Computer will not recognize universal USB when plugged into USB port.
I recently purchased the Phillips Universal USB from Amazon for my mp3 player; my previous one broke and now I have no way of hooking it up to my computer and putting new music on my mp3. The problem is when I plug in the usb the computer does NOTHING, nothing pops up. Nada. When I plug in other...
Hardware & Devices
USB 3.0 port won't recognize USB 3.0 hard drive
Hi everybody, I have an Asus U46e-BAL5 and was really happy with the USB 3.0 port as a future proof technology. I didn't get to use it until I purchased a Western Digital My Passport Essential SE 1TB USB 3.0. Everything ran smoothly the first few months, but recently, things have been strange....
Hardware & Devices
[HELP] USB Flashdrive Problem
I'm having a problem with this particular USB flashdrive. Whenever it was inserted, USB Disk Security detects it and reports as there's no threat from malwares in the said flashdrive, but it doesn't show up in the 'My Computer' screen. I tried remapping the drive letters of some virtual drives in...
Hardware & Devices
