Windows 7: Help with Front Panel/Power Button Connector
01 Jan 2016   #11
JaxDrumm
Windows 7 Home Premium 64-bit SP1
I tried that for about three hours straight yesterday, no luck.
01 Jan 2016   #12
Mellon Head
OK. I need a little more background...
It's a Dell motherboard. What kind of power supply is it? What make and model? If the power supply is not a Dell, maybe it isn't compatible with the Dell motherboard. HP pulls tricks like that all the time. The pinouts on the main power connector are different than the industry standard and a standard PSU won't work.
And you did check all of the electrical connections like I asked you to, right?
01 Jan 2016   #13
JaxDrumm
Okay, something weird happened earlier...
There is a spot in the middle which is a "hotspot" of sorts, as in that's the only place where the led or switches will work... but my case smells hot when I do it, like something is smoking...
My case is a Rosewill Challenger S and my PSU is a Corsair CX 750.
01 Jan 2016   #14
Mellon Head
The middle of what?
01 Jan 2016   #15
JaxDrumm
Front panel connect on the mb, sorry for not making that clearer
01 Jan 2016   #16
Mellon Head
Ok. It looks like you have a short somewhere. And you've started another thread. PIck a thread and stick to it.
I'm out.
01 Jan 2016   #17
Ranger4
Jax has posted virtually the same thing here,
Help with Power Switch/PSU?
I have suggested that his MB maybe contacting his new case at some point & shorting, which seems like it might be so from his post #13 in this thread we are on now.
How to Windows-disable the front-panel restart button?
In http://www.sevenforums.com/hardware-devices/295913-spontaneous-restarts-perhaps-seemingly-caused-power-switch-help.html I describe a bothersome situation where, as of now, it appears that my PC is rebooting itself once in the morning upon being woken from sleep and logged into, then behaves fine...
Hardware & Devices
Power/sleep button, closing panel options greyed out
Hi, I am new to windows 7 and i would like to change these settings: ImageShack® - Online Photo and Video Hosting I don't get why it's greyed out. I have a samsung series 9. I have seen something about fast start, but I don't have that application. I removed all the bloatware from my...
Performance & Maintenance
Front Panel Audio connector help needed
So I basically have a very odd front panel audio connector setup, very confusing, I've made over 10 thread on different forums and non were able to help me. I'm using a Gigabyte G31 motherboard GIGABYTE - Motherboard - Socket 775 - GA-G31M-ES2L (rev. 1.x) Manual page for the motherboard...
Hardware & Devices
What to do with a Dell front panel connector & new mobo
I was just posting about power supply issues here. I ran over to Radioshack and they actually had a 350W psu I snatched up. But the blasted thing still won't turn on. The last thing standing in my way is this darn front panel cable. It is a bunch of, thankfully individually labeled, wires for the...
PC Custom Builds and Overclocking
Sleep Mode affecting front panel LED power light?
Hello, I just had my new build finished and it's been running for a day. Well, I'm new to windows 7 and I hadn't turned off sleep mode yet. Well, I stepped away for a few and came back to find that my pc was in sleep mode. I reeactivated the pc and everything kicked back on except for the...
Hardware & Devices
Front usb connector problem
I have just changed my system from a large case to a matx case, but used all the part except the mainboard. Changed from a Asus P6T Deluxe to a Asus Rampage Gene II. Now I thought I might have to reinstall windows, but as luck would have it, it booted straight into windows with no other problem...
Hardware & Devices
