Windows 7: Help with Front Panel/Power Button Connector
31 Dec 2015   #1
JaxDrumm
Windows 7 Home Premium 64-bit SP1
Hello! Recently, I transferred my Dell Motherboard (From an Inspiron 560) to a new Rosewill Challenger-S case. All of that went fine and dandy but now I'm facing another problem: I don't quite know where to plug up the cables from the case's front panel (power switch, reset switch, HDD LED). I found a port on my motherboard labeled "Front Panel" which matches the ports, but one is missing like normal front panel connectors, and the cables only take up 6 out of the 9 pins. So the real question is, where do you plug up the cables, or do you even put them in that spot?
Sorry if that sounded really nooby,
JaxDrumm
31 Dec 2015   #2
Mellon Head
Take a close up picture of your motherboard and post it so we can see it. please.
31 Dec 2015   #3
JaxDrumm
Pictures of port + Cable
Help with Front Panel/Power Button Connector-20151230_221943.jpg   Help with Front Panel/Power Button Connector-20151230_223910.jpg
31 Dec 2015   #4
JaxDrumm
Sorry for the low quality, trying to hold cables while balancing a flashlight and tablet to take a picture is hard on a bed, and focusing was a pain.:\
31 Dec 2015   #5
Mellon Head
Thanks for the pictures. That is definitely the correct spot to plug in the cables, according to the service manual for your PC. The problem is that the service manual doesn't show the pinout of the connector. Dell helpfully mentions that you should take careful note of where the cables are unplugged from so that you can reassemble them when you're done. Not very helpful in this case.
This is a common pinout for Foxconn and Dell motherboards (Foxconn makes a lot of Dell motherboards, btw).
Help with Front Panel/Power Button Connector-dell-560.png
You could try that pinout (at your own risk). Note that the negative wires on the front panel and HDD LEDs are the white ones. The colors for the power and reset switches don't matter.
I wish I could be more exact on the pinout, but that's all I could find. There is supposedly an exact pinout on this site:
Dell 18D1Y Motherboard Front Panel Pinout - CPUs, Motherboards, and Memory - Linus Tech Tips
But it requires registration.
31 Dec 2015   #6
JaxDrumm
Not anything happening, but I just got my power supply today, how do I check if it's DOA?
31 Dec 2015   #7
Mellon Head
Did you hook up the front panel connectors? Try pressing the reset switch and see if that does anything. If it does, reverse the Reset and Power Switch wires.
31 Dec 2015   #8
JaxDrumm
Nope, nothing. :\
31 Dec 2015   #9
JaxDrumm
Got some info! My motherboard is for the mini-atx version, it's the 0K83V0 Dell Motherboard. But even after trying that pinout at linustechtips, it still doesn't work.
01 Jan 2016   #10
Mellon Head
Ok. Well, that's discouraging.
Just to make sure, you have all of the appropriate power supply wires hooked up? Including the 4 pin CPU power connector up by the CPU? And the power wires connected to the board are in place securely? Also, the power switch on the power supply is turned on? (Don't laugh, I spent a half our debugging that one once.)
What you can do is try the power switch connection only and plug it into the front panel connector in the places you see on the pinout that I linked. Try the different combinations until the motherboard starts up.
If it still won't start up, we have another problem on our hands.
How to Windows-disable the front-panel restart button?
In http://www.sevenforums.com/hardware-devices/295913-spontaneous-restarts-perhaps-seemingly-caused-power-switch-help.html I describe a bothersome situation where, as of now, it appears that my PC is rebooting itself once in the morning upon being woken from sleep and logged into, then behaves fine...
Hardware & Devices
Power/sleep button, closing panel options greyed out
Hi, I am new to windows 7 and i would like to change these settings: ImageShack® - Online Photo and Video Hosting I don't get why it's greyed out. I have a samsung series 9. I have seen something about fast start, but I don't have that application. I removed all the bloatware from my...
Performance & Maintenance
Front Panel Audio connector help needed
So I basically have a very odd front panel audio connector setup, very confusing, I've made over 10 thread on different forums and non were able to help me. I'm using a Gigabyte G31 motherboard GIGABYTE - Motherboard - Socket 775 - GA-G31M-ES2L (rev. 1.x) Manual page for the motherboard...
Hardware & Devices
What to do with a Dell front panel connector & new mobo
I was just posting about power supply issues here. I ran over to Radioshack and they actually had a 350W psu I snatched up. But the blasted thing still won't turn on. The last thing standing in my way is this darn front panel cable. It is a bunch of, thankfully individually labeled, wires for the...
PC Custom Builds and Overclocking
Sleep Mode affecting front panel LED power light?
Hello, I just had my new build finished and it's been running for a day. Well, I'm new to windows 7 and I hadn't turned off sleep mode yet. Well, I stepped away for a few and came back to find that my pc was in sleep mode. I reeactivated the pc and everything kicked back on except for the...
Hardware & Devices
Front usb connector problem
I have just changed my system from a large case to a matx case, but used all the part except the mainboard. Changed from a Asus P6T Deluxe to a Asus Rampage Gene II. Now I thought I might have to reinstall windows, but as luck would have it, it booted straight into windows with no other problem...
Hardware & Devices
