Windows 7: Help with Power Switch/PSU?
31 Dec 2015   #1
JaxDrumm
Windows 7 Home Premium 64-bit SP1
Okay, so this is a continuation of this thread: Help with Front Panel/Power Button Connector
Okay, so I don't know why, but when I have the 24-pin connector for my motherboard halfway in (or halfway out, if you're that kind of guy) all of my led fans kick on, but none of my front panel configurations can turn it on. Please see the above thread for more information!
31 Dec 2015   #2
bigmck
Maybe you could continue posting on one thread.............
31 Dec 2015   #3
JaxDrumm
Well, the problem kind of spread to other areas...
Such as the all the fans working up when the 24 pin power connector is halfway in. Why is that?
31 Dec 2015   #4
bigmck
Suit yourself.......
31 Dec 2015   #5
Ranger4
From what you have said here & in your other post, you have changed the motherboard to a new case, so you really need to check that the MB is standing proud of the case & there are no points of contact other than the mounting screw points.
You also mention that the fans work if you have the 24 pin connector half way in, but not if fully in, so this also confirms the possibility that the MB could be shorting onto the case.
All connectors should always be fully inserted.
01 Jan 2016   #6
JaxDrumm
Looking for points of contact now
Prevent switch from Balanced power mode to Power Saver mode
Hello, My computer seems to switch to Power Saver mode of its own volition. I'm not sure what triggers the switch from Balanced mode to Power Saver. Yes, I know and how to prevent screen dimming and sleep mode, and I know how to change the plan settings for any power mode... ...but what is...
General Discussion
Any way to auto switch power plans when plugging in to charger?
anyone know how to do this? when plugging in to AC adapter, the system switches to a different power plan?
Performance & Maintenance
Spontaneous restarts, perhaps seemingly caused by power switch? Help!
Very frustrating situation here. Sorry, please read all my situation because there are some twists and turns. Start with http://www.sevenforums.com/general-discussion/272039-computer-does-random-restarts-after-putting-350-watt-psu.html which describes a startup/spontaneous restart problem I...
Hardware & Devices
Can I use Power over Ethernet (PoE) with any switch ?
Can we connect Power over Ethernet (PoE) Adapter just like this one D-Link Power over Ethernet (PoE) Adapter Kit with any Ethernet switch ? I have a Belkin 5-port 10/100 switch can it be powered by PoE ? How it will be setup.
Network & Sharing
Is there a quicker way to switch between win7 power options
I regularly need to switch between "power saver" and "high performance" on my vaio laptop. I do this via going into "power options" and selecting the appropriate option when i require it. What I want to do is add a shortcut to the desktop or windows toolbar, but i cannot find a method to do this....
Switch to Windows Aero Basic when on Battery Power
Hey guys, wanted to ask a question. Is there a way to have Windows 7 switch to Aero Basic when on battery power. I see that when on the Power Saver mode, it turns off transparency when on battery power. I guess this is enough, but if it was to disable Aero, would that give me more battery life,...
Hardware & Devices
