Windows 7: Will sudden cable connection problem affect hard drive in the long run
05 Jan 2016   #1
LearningTeam
windows 7
When the cable of an external drive is awkwardly plug in and cause the following error (not exact wording)
'An error was detected on device during paging operation' and 'unable to flush data to transaction log'.
Will there be a long term effect on the drive since the problem is only cause by not plugging the cable properly.
05 Jan 2016   #2
Ranger4
Hi LearningTeam, welcome to the Forum.
I doubt the hard drive will be affected but there might be a problem with the data transferred during that time. So check to see if the data is still working correctly.
06 Jan 2016   #3
LearningTeam
windows 7
In other word, if the data are transferred again there will be no problem?
What if the drive is upside down when it is in use will that cause any problem? Not sure if its upside down, both side look the same...
06 Jan 2016   #4
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
Upside down, sideways, it won`t hurt the drive. But what is the problem with the power connection ?
I would fix that right away before you kill the drive.
06 Jan 2016   #5
LearningTeam
windows 7
Thanks for the reply and it was in an awkward positions when plug in which cause the error. Just wondering if there will be any long term effect cause by the error.
06 Jan 2016   #6
Ranger4
As mentioned there should be no long term problem with the drive, but just make sure it does not happen again. The main thing to watch with external drive is not being exposed to physical shocks, such as dropping it, knocking it over or similar events.
07 Jan 2016   #7
LearningTeam
windows 7
What about when a external drive is plug in for the first time and the pc says something along the line of 'unable to install driver' yet the hard disk can be access, when plug in the second time it does not try to reinstall driver.
Does that mean it is usable or not usable?
07 Jan 2016   #8
AddRAM
It should only install the driver 1 time, as long as you can use it, you`re fine.
External Usb 3.0 hard drive used as internal affect performance?
Hello all. I need some more space and I have a extra 1tb external hd. I want to turn my usb 3.0 external into a sata internal. Will this be the same performance as a regular internal drive with same specs(like if both are 7200rpm). Isn't it the same thing? Or external not made to be as good as...
Hardware & Devices
Sabrent hard drive cable kit
I have a Toshiba Satellite, model L855D-S5220, is there a new chipset driver available, and will it fix my Sabrent hard drive cable kit so my pc will detect external hard drives again? I've been trying to fix this issue for a while, with no luck
Hardware & Devices
Hard drive cable not sure if it needs replacing
I have an HP windows 7 64bit Fully updated via windows update. Over the years I have slowly upgraded parts inside here and there. One of the things I upgraded was the harddrive from 750gb to 1TB...The old one went out had bad sectors. Everything has been working fine for years and...
Hardware & Devices
Cable Connection Problem
Hi, I have a cable connection that once in a while slows down to unusable speeds. The unplug/plug method usually works. I have a linksys WRT54G wireless router and connected through wifi. Is there any way to mimic the unplug/plug method without actually doing it, like a program that does the same...
Network & Sharing
How will a hard drive clone affect WinRE?
Heyo forum-goers, what I am trying to do is sort of complicated but I'll try my best to explain it. Basically I'm trying to squeeze every ounce of potential out of my nearly outdated machine. First, my relevant system specs: - Windows 7 Pro 64bit - 2 IDE Hard drives - 5400rpm 80GB Maxtor,...
General Discussion
External Hard Drive and Cable
As soon as I receive the DVD, with Windows 7 in October, I plan to put it on an external hard drive. After I am sure that all is working well, will I be able to transfer it to my Computer Drive C; if so is there a special cable that I should use (such as the special cable needed for Windows Easy...
Hardware & Devices
