Windows 7: My Monitor goes to sleep after 10 minutes, screensaver none, power....
08 Feb 2016   #11
torchwood
settings
Hi Axely,
I've put a call out regarding the fact you dont have those multimedia options. Unusuall
Do you have Windows media player installed, or any other, ie VLC
Please fill in your comp specs Make/model/ graphics card etc, it will help
Roy
08 Feb 2016   #12
Anak
Win 7 Home Premium 64bit Ver 6.1.7600 Build 7601 - SP1
Yes, please fill in your system specs especially the make/model of your display monitor. TW I have multimedia even with the balanced setting
Some monitors will have their own sleep settings, but we can not guide, if we do not know.
08 Feb 2016   #13
derekimo
Regarding the multimedia settings:
Cannot see Multimedia Settings under "Change advanced power settings"
Are media features enabled in Windows features?
Windows Features - Turn On or Off
Monitor randomly enters power save mode within 3 minutes of startup
Since today my custom built computer has been having issues with all the attached devices. I left my computer on so that I could watch a stream on twitch.tv, I paused the stream and left my computer running without being used for about 3 hours ( the only thing running was google chrome and like...
Hardware & Devices
Screensaver and power off monitor not working
I have build 7068. From the start my screensaver and power options are not working. The problem is sometimes they DO work. I am having trouble diagnosing it because of that fact. What would cause this? I just want the monitor to turn off 30 minutes after stop using the computer. That's the main...
General Discussion
Black screen/monitor goes to sleep minutes after powering on
A matter of minutes or even seconds after powering on, the screen goes black. There is a "no signal detected" message is displayed. That is to say, the monitor has gone in to sleep mode. Sometimes a slightly louder whirring noise can also be heard for about a second or two before the monitor goes...
Hardware & Devices
Monitor keeps turning off after 15 Minutes(Power Options are on Never)
Hi, I know this has been asked a million times on the web already but its seriouslly annoying me now. Windows 7 Ultimate (x64) keeps turning the monitor off after 15 Mins of in-activity. However - before it does that at 14 Mins and 30 Seconds it sorta does a quick flash - then at...
General Discussion
Sleep Mode, Screensaver, Power Options not working
I've had my ASUS for only a few months and it works like a charm, but I noticed a few days ago that it's not going into sleep mode anymore. The only changes I've made were: 1. Installed nod32 (antivirus) 2. Changed my desktop wallpaper 3. Installed the Adobe update That's it. I didn't...
General Discussion
after 4 minutes monitor wakes up from power saver mode
I set my screen saver to blank after 4 minutes and my monitor to power down after 5 minutes. After 4 minutes I hear the Windows seven default sound for log off (I think) and the screen powers up but the blank screen saver stays on. This only happens when I have a check mark by show the welcome...
General Discussion
