Windows 7: My Monitor goes to sleep after 10 minutes, screensaver none, power....
04 Feb 2016   #1
Axely
windows 7 professional x64
hello i am new to the forum, Well i am getting really frustrated that my monitor goes to sleep after 10 minutes of inactivity, but my computer still runing,video still playing, music still playing, just my monitor decided to go to sleep for no reason, and i have to move my mouse to get it wake up again. i have set my screensaver to off, and power option to never, and it is still happening. i might not be the only one here having the same problem, if anyone have any solution that could help me out please do , i will really appreciate it ;c
04 Feb 2016   #2
oscer1
win 7 64 bit
Hi welcome to the forum
what do you have your monitor to do after a certain time? go to control panel power options on left hand side of screen choose when to turn off the display
05 Feb 2016   #3
Axely
its set to never alreaady, but still getting the same problem
07 Feb 2016   #4
Axely
bump
07 Feb 2016   #5
torchwood
advanced
Hi Axely,
I use high power option, with these options, give them a try
Roy
My Monitor goes to sleep after 10 minutes, screensaver none, power....-power.png
07 Feb 2016   #6
Axely
hmm weird, i do not have that option "multimedia setting"
07 Feb 2016   #7
torchwood
high
Did you look at the
HIGH performance section, of power options, NOT balanced.
Roy
08 Feb 2016   #8
Axely
yes i did
08 Feb 2016   #9
Axely
08 Feb 2016   #10
oscer1
win 7 64 bit
Can you try another monitor or if monitor has another type of input try that.
Monitor randomly enters power save mode within 3 minutes of startup
Since today my custom built computer has been having issues with all the attached devices. I left my computer on so that I could watch a stream on twitch.tv, I paused the stream and left my computer running without being used for about 3 hours ( the only thing running was google chrome and like...
Hardware & Devices
Screensaver and power off monitor not working
I have build 7068. From the start my screensaver and power options are not working. The problem is sometimes they DO work. I am having trouble diagnosing it because of that fact. What would cause this? I just want the monitor to turn off 30 minutes after stop using the computer. That's the main...
General Discussion
Black screen/monitor goes to sleep minutes after powering on
A matter of minutes or even seconds after powering on, the screen goes black. There is a "no signal detected" message is displayed. That is to say, the monitor has gone in to sleep mode. Sometimes a slightly louder whirring noise can also be heard for about a second or two before the monitor goes...
Hardware & Devices
Monitor keeps turning off after 15 Minutes(Power Options are on Never)
Hi, I know this has been asked a million times on the web already but its seriouslly annoying me now. Windows 7 Ultimate (x64) keeps turning the monitor off after 15 Mins of in-activity. However - before it does that at 14 Mins and 30 Seconds it sorta does a quick flash - then at...
General Discussion
Sleep Mode, Screensaver, Power Options not working
I've had my ASUS for only a few months and it works like a charm, but I noticed a few days ago that it's not going into sleep mode anymore. The only changes I've made were: 1. Installed nod32 (antivirus) 2. Changed my desktop wallpaper 3. Installed the Adobe update That's it. I didn't...
General Discussion
after 4 minutes monitor wakes up from power saver mode
I set my screen saver to blank after 4 minutes and my monitor to power down after 5 minutes. After 4 minutes I hear the Windows seven default sound for log off (I think) and the screen powers up but the blank screen saver stays on. This only happens when I have a check mark by show the welcome...
General Discussion
