Windows 7: External WD 2TB Hard Drive Problem (corrupted)
02 Mar 2016   #11
jumanji
Windows 7 Home Premium 32 bit
@maxseven, that won't work rather it can't be made to work.
a. WD My Passport is hardware encrypted and decrypted by the electronics inside the enclosure. If the drive is taken out and tried and assuming that the HDD itself is OK, what all you will get is the encrypted data which will be absolutely useless garbage.
b. In most of the WD external drives the SATA to USB bridge ( that incidentally includes the encryption and decryption chip) is integrated with the hard drive and hence the HDD itself may be inseperable.They are bonded together, live together and die together - as for as the user is concerned. .
In case of failure of the electronics inside the enclosure, only WD authorised - patronised - data recovery partners can recover the data since only they have the knowhow to decrypt.
In case the electronics has not failed, then any data recovery attempt has to be made without separating the electronics from the drive to be able to get the decrypted data.
02 Mar 2016   #12
maxseven
Windows 7 Home Premium 64bit 6.1 Build 7601 (SP1)
Quote   Quote: Originally Posted by jumanji View Post
In case of failure of the electronics inside the enclosure, only WD authorised - patronised - data recovery agencies can recover the data since only they have the knowhow to decrypt.
I didn't know any of that about the WD Passport; hopefully the OP knows this too, or sees your post before tearing the thing apart.
If it's anything like some of the products I have, it's next to impossible to disassemble them without breaking something. Why oh why do mfrs do this to us...
08 Mar 2016   #13
sgn15
Windows 10 64-bit
The symptoms changed:
In device manager:
still seeing it under Disk Drives
In Disk Management:
I can see the disk now but it says it is uninitiated
- tried initiating it but it says fatal hardware error
In My Computer/This PC
I cannot see it anymore (it used to show Disk G with no volume or no bytes used/free)
Any ideas?
08 Mar 2016   #14
sgn15
Windows 10 64-bit
Urgent:
I try different data recovery softwares on my hard drive and they all scan for a maximum of 2 secs and they show no files searched/found and my external HDD is listed as o bytes and start sector is 0 (I forgot but it wasn't 0 before or it shouldn't be 0). Is this raw or what issue?
EDIT:
I am not a techy guy but from what I have searched. The Master Boot Record somehow got ruined on this already corrupted hard drive? That's why the symptoms changed and (I think) it got worse?
It somehow retained the hanging the other programs symptom and can't even run TestDisk (it is stuck forever at Please wait after I select create a log)
Any ideas please?
08 Mar 2016   #15
maxseven
Quote   Quote: Originally Posted by sgn15 View Post
Your drive has failed and the recovery software can't even see the data on the drive.
Your only recourse to possibly recover any data at this point might be one of the specialty data recovery services.
09 Mar 2016   #16
CKWD
Your external drive has been damaged too severely and trying data recovery software on it on your own could potentially make it completely unresponsive, due to the degree of damage it has endured.
Safest route would be to use professional data recovery help and/or check the drive for RMA. I have pasted some links in my first post, I hope they can help, here they are:
WD data recovery partners:
Support Answers
WD Warranty check:
Support Answers
WD Warranty Policy:
Support Answers
Best of luck!
CK_WD
External hard drive corrupted, CHKDSK stalls at 76% complete
I am trying to fix a new Toshiba Canvio 3.0 1.5TB drive that has errors. Each time I plug it in, I'm directed to run CHKDSK, but CHKDSK fails to complete with the /f parameter. The process stalls at 76%. If I run CHKDSK without the /f parameter, I get the following result: Again, if I run...
Hardware & Devices
external hard drive problem
i have a freecom external hard drive and it has stopped working not sure why it as all my photos on it. it just stopped showing the drive. i have taken it out of case and tried in pc still not found but when i try program file scavenger it finds it all my files are there what could be wrong with...
Hardware & Devices
WD External hard drive problem from no where?
Ok. Well my external hard drive is about 3 months old. I have videos, pictures and my itunes library on it. It has been working without a flaw up until now. I plug it in, type in password, click the vid or pic I wanna view and i get "discovering" or "cant find file/cant read file or cant read...
Hardware & Devices
External Hard Drive Problem
My fiancee has an external hard drive from Fabrik, a SimpleDrive. Its a TB in size. He's using it on his Windows XP. However, yesterday it stopped working. Sortve. It works in that the light comes on when its plugged in and powered up, and it shows up in the device manager, but he cannot access it...
Hardware & Devices
USB External Hard Drive Problem
When using a USB external hard drive on my old computer with Windows XP, I could delete and add videos with no problems, and then simply defragment that drive from time to time. Now with my new computer and Windows 7, I am finding that when using the same USB external hard drive to delete and add...
Hardware & Devices
External hard drive problem! please help!!!
I was using Win XP on my Toshiba Satellite A215 S5818 until yesterday, now im using windows 7, so i insert my Transcend Storejet external hard drive, it was working perfectly like it used to. So i left my lap top running through the whole night because i was downloading something. I get up this...
Drivers
