External Hard Drive Problem
  1. Posts : 109
    Windows 7 Home Premium 64 Bit
    I have an external hard drive and I plug it in and the computer recognizes it and it appears in My Computer as drive J, but when I try to save something to it I get the following error:
    J:/ Passwords 3.png
    You do not have permission to save in this location
    Contact the administrator to obtain permission
    Would you like to save in the My Pictures folder instead?
    I'm logged in as administrator and have never gotten this error message before help!
    Edit: If I drag the file from the My Pictures folder to the J: drive it ask me to give administrator permission to copy it and I do and it copies it just fine.
  2. Posts : 1,614
    Windows 7 Pro & Vista Home Premium
    Well,
    First you should be saving to the root of the J: drive.
    haven't you setup folder to place your files in.
    It could also be due to permission problems. if the first suggestion doesn't work, simply post back.
  3. Posts : 109
    I was trying to save it to the root of the J: drive.
  4. Posts : 109
    Still having problems!
  5. Posts : 109
    Bump!
  6. Posts : 109
    Bump!
  7. Posts : 1,614
    Is it a USB external?
    If so, have you tried other ports?
  8. Posts : 109
    Yes and yes I have I just get the same problem.
  9. Posts : 867
    XP, Vista, W7 64bit Home Premium
    You could try this solution :
    Control Panel - Administrative Tools - Computer Management - Disk Management
    Right click on the drive in diskmanagement, or computer folder - properties - security - advanced - owner - edit - then change owner to yourself.
