Windows 7: External Hard Drive Problem
17 Nov 2009   #1
cgrim29588
Windows 7 Home Premium 64 Bit
I have an external hard drive and I plug it in and the computer recognizes it and it appears in My Computer as drive J, but when I try to save something to it I get the following error:
Quote:
J:/ Passwords 3.png
You do not have permission to save in this location
Contact the administrator to obtain permission
Would you like to save in the My Pictures folder instead?
I'm logged in as administrator and have never gotten this error message before help!
Edit: If I drag the file from the My Pictures folder to the J: drive it ask me to give administrator permission to copy it and I do and it copies it just fine.
17 Nov 2009   #2
reghakr
Windows 7 Pro & Vista Home Premium
Well,
First you should be saving to the root of the J: drive.
haven't you setup folder to place your files in.
It could also be due to permission problems. if the first suggestion doesn't work, simply post back.
17 Nov 2009   #3
cgrim29588
I was trying to save it to the root of the J: drive.
17 Nov 2009   #4
cgrim29588
Still having problems!
17 Nov 2009   #5
cgrim29588
Bump!
19 Nov 2009   #6
cgrim29588
Bump!
20 Nov 2009   #7
reghakr
Is it a USB external?
If so, have you tried other ports?
20 Nov 2009   #8
cgrim29588
Yes and yes I have I just get the same problem.
20 Nov 2009   #9
whest
XP, Vista, W7 64bit Home Premium
You could try this solution :
Control Panel - Administrative Tools - Computer Management - Disk Management
Right click on the drive in diskmanagement, or computer folder - properties - security - advanced - owner - edit - then change owner to yourself.
External Hard Drive problem
When I connect my 1TB Buffalo MiniStation to my PC, -it does not show up on 'My computer'. The 'safely remove device' option is there. The device is also visible in Disk Management. I googled around for some time and the most common solution offered by others was to assign a drive letter to the...
Hardware & Devices
External Hard Drive Problem :(
:( I think Mere Hard Drive mai Virus hai. Hard Drive ki space y show kar rai hai k external hard mai data hai . but in folder wo show nai ho rha ...... My Hard drive show data space in properties . But Data not show in drive . I this Its virus. Kindly recomend good Antivirus software :(:(:(
Hardware & Devices
External hard drive problem
My Xternal hard drive that I have had for awhile,is being dropped while I am using it.Then when I go back to open it again,it is not even listed on my computer. I have windows 7 ultimate 64.It is a small drive HDDgear is the name.I have un plugged it and tried it on another computer with XP and it...
Hardware & Devices
WD External hard drive problem from no where?
Ok. Well my external hard drive is about 3 months old. I have videos, pictures and my itunes library on it. It has been working without a flaw up until now. I plug it in, type in password, click the vid or pic I wanna view and i get "discovering" or "cant find file/cant read file or cant read...
Hardware & Devices
External Hard drive problem
I have a 2.5 sata 250gb hard drive from a laptop with a broken screen. I bought a enclosure for it so I could use it as a external hard drive. During the process of backing up and clean up I apparantly deleted something important because it started saying the drives (the hard drive has a recovery...
Hardware & Devices
hello,,, my Ext. HD is not working,,, until now, it said that it's not recognized... but the disk is running...... finish for checking cables but it's still not working...updated the driver, still not working i always keep it in the safe place,.... i give you the screenshot......
Hardware & Devices
