Power supply cord question
  1. Posts : 76
    Windows 10 Pro 64-bit
    So my power supply used to have this cord:
    imgbox - fast, simple image host
    But I moved to a different country which uses the Type F (according to this: Plug & socket types - World Standards)
    The only thing I noticed is that the old (original) power cord that came with the PSU, 10A 125 V was written on it. The new one I bought to fit the sockets here, has like 16A 250V written on it. Will it be okay to use that? Or will it cause problems on my PSU or PC?
    Thanks!
  2. Posts : 1,670
    win 10
    hi you should be fine I think that power supply auto detects ac voltage some power supplies their is a switch you move to tell what input voltage your connecting too.
    AURUM S 650W | Power Supply | FspLifeStyle
  3. Posts : 201
    Windows 7 Professional x64, Arch Linux
    One thing to keep in mind: based on the page you linked, type F cables are compatible with type C, E, & F sockets. But type C sockets aren't grounded, so make sure you never plug in to one of those.
  4. Posts : 76
    Thanks guys! :)
  5. Posts : 1,670
    win 10
    Your welcome
