CPU core speed lowers from 2.6Ghz to 500mhz after a bit
Trying to figure out if I can fix this laptop cheap or not. I think the issue stems from overheating in the past. I know it isn't software as I just formatted and installed a fresh Win10 copy. After using the computer for a bit the CPU core speed reported by CPU-Z goes from around 2.6Ghz to around 500Mhz. Oddly though the CPU core temperature isn't that hot and like 110 Fahrenheit.
Anyone know if it's the CPU temperature sensor that triggers lowering clock speed or the motherboards? Open Hardware Monitor didn't detect a sensor for my motherboard, but maybe it has one not known by the software. Sometimes when this lower clock speed happens the laptop bottom feels hot, other times it feels normal. Not sure what to do. Maybe I should buy a new fan and just give it a try? Any advice?
