HELP! DVD Drive undetected after MagicISO
  1. Posts : 5,807
    sloppyjojo said:
    the thing is that i can't even play the dvd anymore, since the dvd drive is missing...
    hm...downloading an ISO of the RTM and extracting the files to perform the repair install is a way...
    Reinstalling the entire OS from scratch is another (probably not desired)
  2. Posts : 632
    windows 7 x64 Home Premium
       #12
    Did you try Safe Mode? If you can "see" the DVD in Safe mode, then its a corrupted driver issue, and a simple driver download will fix it.
  3. Posts : 17
    Windows 7 Ultimate 32bit
    I've tried to boot both in Safe Mode can Clean Boot, but DVD still is not appearing on the Device Manager.
  4. Posts : 176
    Windows 7 Ultimate x64 RTM
       #14
    Didn't see it asked. Is it detected during POST and in the BIOS
  5. Posts : 17
       #15
    I FOUND THE SOLUTION, GUYS!!!
    I checked out other sites, and I saw one, these were the steps that I had to do:
    1. Click on Start > All Programs > Accessories > Right click Command Prompt > Run as administrator.
    2. Paste the following line into the Command Prompt window and hit Enter
      bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
    3. Restart the computer.
    After I restarted, I checked on Computer... and VIOLA! My DVD drive is back!
  6. Posts : 5,807
       #16
    It might be fixed but this has me a bit worried...
    That flag is in check to detect that the hardware is alright at boot (I believe)...this is a safeguard and I still recommend that you backup and do a clean install
  7. Posts : 685
    Windows 7 32bit RTM
       #17
    and its confirmed magicISO ain't compatible with windows 7.... I suggest powerISO!
  8. Posts : 2,606
    Windows 7 Pro X64 SP1
       #18
    I haven't used it a great deal, but I've had no trouble with MagicISO 5.5 build 274 under Win7 X64.
    (I haven't tried the slightly newer build 276.)
  9. Posts : 17
       #19
    i'm not sure of it's compatibility. but i did use the older version of MagicISO (the one that was for Vista), which may have caused the issue.
    it's always better to be safe then sorry. so i'll probably not use MagicISO for awhile. (that's just me)
  10. Posts : 16,161
    7 X64
       #20
    I've got MagicIso installed - no problem here.
    The separate virtual drive I don't use.
    It seems to interfere with my other virtual drives.
      My Computers
