Windows 7: Plug in GTX 260, hooked up one 6 pin power plug, motherboard wont post
01 Sep 2016   #1
sdowney717
I verified the PSU is good.
I removed all drives, all cards, even memory.
All the fans spin for a moment then nothing they stop.
I assume the MB is now destroyed? A GTX 260 has two 6 pin power connectors, since the PSU only had one 6 pin power connector, I thought to try it.
MB is Asus P5QC
So is it dead?
01 Sep 2016   #2
Megahertz07
Windows 7 HP
Did you read the GTX 260 manual to see if it has to have the two connectors on?
This is an old MB, so it has a story. Tell us how did you get it and what memory, GPU etc it has before.
With no memory it won't boot. Do you have a speaker connected to the MB so you can hear the beeps when you turn it on?
Witch power supply you have? GTX 260 requires 500W as minimum.
01 Sep 2016   #3
sdowney717
I have had the MB for about 5 years, been on continually, never powered off.
Of course no did not read any manuals.
It has two 4gb DDR2 sticks.
No speaker connected, it has some kind of beeper onboard, no beeps anymore, it used to beep.
THE PSU is a 650 watt, but see only had one plug. Maybe it drew too much power at boot thru the pciex16 slot and fried the board.
My plan is to remove it and clean it and retry it.
This board always had a weird bootup.
It would start then shut down completely, then in a few seconds it would start and boot the os.
There is some kind of dual bios backup, and I think one was corrupted so it would default to the other.
02 Sep 2016   #4
Megahertz07
Windows 7 HP
Don't think the main power for the GPU comes from the PCIe slot. It certainly comes from the 6 pin power connector and the two are parallel on the board. I'll guess that one is good, two is better.
No beeps aren't good.
I'll try fist another graphics card.
02 Sep 2016   #5
RainoT
moin guys
run into same issue long time ago
gtx 260 needs both 6 pin to work
without (or only one connected) fans move a bit when powered on and thats it
02 Sep 2016   #6
Layback Bear
Windows 7 Pro. 64/SP-1
Your card specs show the need of two (2) 6 pin power connections.
GeForce GTX 260 | Specifications | GeForce
Quote:
Thermal and Power Specs
Maximum GPU Temperature (in C)
105 C
Maximum Graphics Card Power (W)
182 W
Minimum System Power Requirement (W)
500 W
Supplementary Power Connectors
6-pin x2
If your power supply doesn't offer enough connections I would recommend getting another power supply that does.
It's very unusual that todays modern power supplies don't offer two (2) 6 pin connectors for a video card.
Please post a site showing what power supply you are using.
Please fill in your (My System Specs) completely.
Look at my (My System Specs) and you will get a idea of helpful information that can be included.
03 Sep 2016   #7
RoasterMen
Windows 10 Pro 64-bit
The card ends up not getting enough power so it will fail to boot to avoid any problems with the hardware.
03 Sep 2016   #8
sdowney717
I understand that the GTX260 card prevents a boot if not enough power.
I pulled out the card and put in a low power card, tried two, and it wont boot.
I took out the memory, turns out is DDR3. Memory works fine in another PC.
PSU works fine in another PC. Leaves the MB or CPU as the problem.
PSU is this one, only a single 6 pin pcie connector.
Lead Power GOLD ATX 12CM Fan 650W Silent Power Supply w/20-24pin SATA PCI-E
Actually this has been a very good PSU, it is also very silent on the RF bands. And it is very light weight.
03 Sep 2016   #9
Layback Bear
If this is your power supply you have more than one problem. One being the power supply.
A low quality or defective power supply can cause all kinds of problem. Some of those problems can only be checked by replacing hardware with known good hardware.
The first step is installing a quality power supply and working from there.
https://www.amazon.co.uk/650w-Gold-S.../dp/B0016ZOH7A
I would not trust that power supply in a dumpster.
A very light power supply is another indication of lack of quality of a power supply.
It's very light because needed quality components have been left out of the power supply.
Putting that power supply in another computer to test is risking the other computer.
Please note:
Their is no such thing as a cheap quality power supply.
Just my opinion.
Jack
03 Sep 2016   #10
sdowney717
I also though of that too.
I suppose the PSU could have spiked the voltages when under startup load of that card and fried it.
OR it was just the MB time to fail.
But that PSU has worked fine on another 6 core AMD MB for years, since 2011 being on continuously.
Specifically this here
AMD FX(tm)-6300 Six-Core Processor
Manufacturer: MICRO-STAR INTERNATIONAL CO.,LTD
Product Name: 760GM-E51(MS-7596)
That is the system I am currently using now, and a GT610 Nvidia card, and 16gb DDR3.
The P5QC board was having boot issues for years, it would when you power on, spin the fans, then stop and a couple seconds later startup normally. Which I never could figure out. Years ago, I updated the bios, and there seemed to be a backup bios, so I wonder if the bios is wrecked? After I had ubdated the bios, it started doing the weird boot up, this was years ago.
The sequence of events was I had an Asus p5QC with an Nvidia GT610 with 8gb ddr3
I pulled a GTX 260 out of another PC I use for WMC, and went with onboard DVI video.
So then thinking I would like to run the GTX260 in my Asus board, required a PSU with more oomph, so took the Lead Power PSU out of the case having the 6 core AMD fx cpu, and put it into my Asus p5QC case.
Search this Thread:
Advanced Search
Seagate back up plus 1 tb reloads when I plug in or plug out the power
I have an external hard drive Seagate backup plus 1 tb working fine with Sony vaio E15136 win 8.1 64 bit 4gb Ram. As long as I change the power supply i.e either plug in or plug out the power supply of my laptop, external drive is re-detected. The external drive draws power from laptop.No external...
Hardware & Devices
Plug in a sata power cable
Can I plug in the power cable to a sata drive (already connected to sata port on mobo), while the computer is on. With that drive connected Windows will not boot (I never have had a problem with the drive before, even when installing windows). If I remember right, a few years ago, I moved the...
Hardware & Devices
when i plug in my headphones or mic my PC wont show a pop up message?
my pc wont show a notification telling me i have pluged in my headset, i am trying to use my mic-build-in kind of headset. when i plug it in nothing happens is if i never had plug it in, my headset also does not appear in my playback devices, shows as 'not plugged in' my headset is the kind where...
Buy plug adapter or new power cord for travel?
I am traveling to Hong Kong in a couple of months. My HP laptop is from the US. It has an external power brick that takes 100-240V. My question is about the cord that goes from the power brick to the wall outlet. The cord has a US plug. Does the cord also take 100-240V and I just need to buy a...
Hardware & Devices
Usb Port wont read anythink i plug in or it keep Disconnecting
everytime i plug my zen into my computer or my Storage device it only connect for a little while also my Missies ipod wont evin connect at all anymore it starting to get really Annoying tryed loads of Way to fix it reinstilling driver, unpluging the plug to reset ports, turned the power...
Hardware & Devices
new cpu cooler, still have to use old cpu fan motherboard plug
hi guys, i recently got the new Ultra ChillTEC Black edition. this cooler comes with all its sensors and controllers built in, therefore it doesnt have to plug into the cpu fan power plug on the motherboard like my original heatsink. however, if i don't have the old heatsink plugged into the...
Hardware & Devices
