Windows 7: Help with Disk Management and how to simplify the hard drive
27 Nov 2016   #1
nicjohns42
Win 7 Professional 64-bit
Hello all,
I am currently trying to figure out what the previous tech did to this user's computer. I should preface this by saying that the end goal is to expand C because it is almost full. As you can see from the attachment, there are three additional partitions after C. I am wondering what the best course of action is to simplify this set up. There isnt anything of major value in the three extended partitions. Mainly, he set up alternate temp directories to them, however I know how to change that. My first question is why is there a page file in both C and E. The one in E is the same size as the RAM on the machine, which I understand is how it should be. The one on C, is like 800,000 kbs, so about a tenth the size it should be. So my question is, if I copy page sys from E to say the last partition, then merge E and F into C (using partition magic). THEN copy and replace the Page Sys file onto C, and finally merge G into C, how safe is doing that (sorry for the run on sentence there). As I previously stated, I really want to simplify the partitions on the drive. Or at least get it so there is more than 30.2 mbs remaining on C. Or is there a better, safer option?
I apologize if any of this is unclear, windows support is not my forte. I can try to clarify anything as needed.
Thanks!
27 Nov 2016   #2
samuria
win 8 32 bit
Welcome to the forum you need to remove e,f,g then grow drive c they are logical drives
27 Nov 2016   #3
nicjohns42
And I imagine it's safer to do this in partition magic? And is it better to delete them, then expand or just merge them?
27 Nov 2016   #4
ignatzatsonic
Partition Wizard is the preferred tool.
I don't see any over-riding reason why you would need logical partitions.
If there is stuff on E, F, and G that you want to keep, copy that stuff elsewhere temporarily.
Then delete E, F, and G and the extended partition which contains them.
Then add however much you want of that recovered space to C.
Then make an ordinary D (not an extended/logical D) of the remainder.
Then move the stuff you temporarily copied back to D and use a standard folder structure on D to categorize your files.
If you don't care about anything on E, F, or G, then just delete those partitions.
Logical and extended partitions are a bit goofy as I recall. You may have to jump through some hoops to get rid of them, but Partition Wizard would still be the tool. Partition Magic is rarely heard of around here--if it's still around at all.
27 Nov 2016   #5
nicjohns42
Someone who has worked on Windows systems longer than I recommended it. And as far as the page sys stuff, do you have an recommendations on how to handle that.
27 Nov 2016   #6
ignatzatsonic
Quote   Quote: Originally Posted by nicjohns42 View Post
Page file??
Let Window manage it.
27 Nov 2016   #7
Eric3742
Windows 7 x64
It is better to show the Disk Management in full, including the percentage of each partition.
Without this, we are guessing only to rely on your words.
As to saying "almost full" is at what %.
Have you go thru the C:\ drive what is inside this system partition.
If there are a lot of "unknown" applications, then you have to decide on whether to continue to use &or remove and uninstall the applications of no use to you.
This is part of removing unnecessary applications in order to regain the wasteful storage.
And in the long term, these unnecessary applications will &or may affect your computer performance to the point of giving you a lot of problems.
This is the time to address on what you need and want as to keep, and remove and uninstall applications.
This clean-up required to look at non application such as data files not related to your usefulness.
The data files are most probably inside the Users folders, which may have used a lot of the storage space, hence the C:\ drive is almost full.
That is to delete the previous users from the profile, totally.
In fact, the previous owner had done a good job, by looking the way the partitions had given some purpose.
Do some housekeeping by review what you need and remove those that are not yours.
In the end, this 100GB for C:\ drive would have plenty of storage space.
In usual Windows system would only occupied 50GB of actual space.
Get the pagefile.sys back to C:\ drive.
As to why.
When there is a change of drives & partitions, sometime system will give another drive &or partition may allocate the label as E:\ drive.
This will in return may cause your system to unable to find the system managed pagefile.sys
You cannot just copy the pagefile.sys as like any other files.
It has to do it within Windows system, and to indicate which partitions..
You need to go directly into the Virtual Memory to see how many "system managed" for /in which partition.
Then do the changes.
Before doing any merge partitions, the data would be lost &or deleted.
Either you create a separate partition just for your data alone.
Until your space is running low, then review the previous owner's data, if any, as being deleted &or empty.
27 Nov 2016   #8
Layback Bear
Windows 7 Pro. 64/SP-1
Completing this tutorial by Golden would make things better to see.
Disk Management - Post a Screen Capture Image
Jack
27 Nov 2016   #9
Lady Fitzgerald
Win 7 Ultimate 64 bit
I would just keep the recovery partition, the C: partition and move all your data to one data partition and remove the other two data partitions, then expand the remaining data partition. Unless you have some large games on it, C: partition seems to have too much on it. If the reason is data on the C: partition, I would move the data off of it and keep only the OS and programs on it.
Before doing anything to the drive, make sure you have at least one backup of the entire drive (two would be much better).
Keeping the system files OS and programs) separate from the data files will make it easier to back up everything. Imaging is the best way to backup system files and folder/file syncing is best for data.
29 Nov 2016   #10
Digerati
Windows 7 Profession 64-bit
Quote   Quote: Originally Posted by ignatzatsonic
Not really a good idea to pretend to speak for everyone. Partition Wizard is NOT my preferred tool. It is good but twice as many others users, including me, prefer EASEUS Partition Master Home Edition over Partition Wizard.
I don't know why you have two page files. You should never have more than one on the same physical drive - that is in multiple partitions on the same hard drive. That just results in excessive R/W head thrashing and can degrade performance.
But you can have a page file on multiple drives. In no way does that degrade performance and in fact, it can improve performance as Windows will use each simultaneously, if needed. And that's a good thing as long as you have enough free space on each drive.
You don't "copy and move" or "copy and replace" page files. Remember, the data saved to a page file is just temporary - put there by the OS to speed up access to that data. So you don't "move" a page file. You simply delete the old and create a new PF on the new drive (if a new one is needed). Technically, you can copy it (with a little trickery), but the OS will not recognize the new copy as a page file, nor will it know where it is because it will not be properly identified in the Registry. So it will just sit there, unused, wasting space.
And I agree completely to just let Windows manage your Page File(s). It knows how to manage memory, and specifically in this case, virtual memory, very well without any user intervention.
BEFORE DOING ANYTHING, however, backup any data you don't want to lose. I've used Partition Master 100s of times over the years and have NEVER lost any data. But ANY TIME you mess with partitions, there is a risk something could go wrong. This is a good time for my standard pitch of recommending every computer be on a "good" UPS with AVR. An untimely power outage in the middle of resizing partitions would likely be disastrous.
Disk Management Help for Hard Drive Used for Storage
Previously, I had installed Windows 7 on a new SSD and also installed a new 1TB hard drive for file storage, photos, and programs. The SSD crashed and I had to get another one. I just installed Windows on it and then added my hard drive, which still has files on it when I ran the first SSD. ...
Hardware & Devices
Can't format hard drive. Tried diskpart/disk management.
Hi guys, I recently bought an SSD and decided to install it on my machine, I've set it as the #1 boot option, and then I tried to format my previous hard drive so I can use it for data. Whenever I right click and do it in explorer, it says "Windows was unable to complete the format". If I do it via...
Hardware & Devices
Trouble re-resizing partitions on my hard drive using disk management.
On my laptop there was originally just one HDD and I wanted all my "Media" to be in one partition and then Programme Files etc. in another (being C). This was just so that I could copy the entire 'Drive' I had created making moving videos and photos around easier. So I used the built in disk...
General Discussion
Hard Drive Doesn't Show in Disk Management
I purchased a 500 GB drive about a year and a half ago to hold my backups for my main 160 GB drive. Just about everytime I have to reboot my PC, the 500 GB does not show in Computer. I them boot again and it shows and everything is fine. I have attempted to sort this out but no luck yet. Today...
Hardware & Devices
160 GB hard drive shows capacity of 55 GB in Disk Management
What would cause a such a large chunk of the hard drive to not appear in disk management - the capacity is approximately a third of the total drive (see attached)!? I have used TreeSize and other tools to see if there is anything out of the ordinary, such as over-sized temp folders, pagefile,...
Hardware & Devices
need help in Partitioning hard drive using disk management
i bought a laptop and it had one drive C(OS) with 450 gb. i want the c - drive to be partitioned further 2 drives(D and E). will i able to do that ,if so please send me steps or screen shots... i followed the below steps: i partitoned using Shrink volume in Disk management and i aplit the...
General Discussion
