DVI Monitor problem
  1. Posts : 6
    Win 7
    DVI Monitor problem
    Hi, I'm new here, and I have one little annoying monitor problem with W7.
    So I have an LG L194WT monitor on a GF7300LE, I have the latest nVidia driver, everything works fine if I only work with the VGA connector, the problem comes whenever I use the DVI connector, I get the bios image fine, then the W7 boot screen fine (I even installed W7 using DVI), but then it goes to a blank image when the logon screen shows up. The monitor works fine in OSX and WXP, so it is a W7 issue.
    I have tried to force detect the DVI connection via the nVidia Control Panel, but it remains the same, a blank, the weird thing is that it detects 2 monitors (both, VGA and DVI cables connected at te same time), but both are listed as VGA display, in XP or OSX are detected as VGA and DVI whenever I plug in both cables... Any ideas about what could be happening?
    BTW, to make the matter worst, when I boot in Safe Mode in W7, the DVI display works fine, just at a lower resolution as expected.
  2. Posts : 6
    Win 7
    So no one has any idea of what could be the problem?
    Any input would be very appreciated
  3. Posts : 1,614
    Windows 7 Pro & Vista Home Premium
    Actually what's listed in Device Manager under display adapters?
    Keep both analog and DVI connects to both the computer and monitor.
    Now try updating you Nvidia drivers.
  4. Posts : 6
    Win 7
    Well at first it showed "Generic PnP Monitor" or something like that on both connections, then I force-installed the drivers LG supplies and now it says LG L194WT (Analog) and LG L194WT (Digital), but if I switch back and forth the drivers, so the analog gets detected as digital and viceversa nothing happens, the device just gets renamed.
    The problem lies, I think, in the way the monitor gets detected, you see, when I go to the nVidia CP, both monitors plugged in are detected as VGA, no matter how many times I plug in or plug out the cables.
    BTW, I already have the latest forceware drivers.
  5. Posts : 1,614
    Strange,
    Can you disable the analog connection an see what happens.
    You have Forseware drivers..but where do they show up?
    Are you looking under Monitor or Display adapter?
  6. Posts : 3,960
    W7 x64
    Check your monitor drivers (these are seperate from your graphics card drivers).
    If you continue to experience intermittant performance then consider the possibility that your DVI cable could be damaged, and/or the pins in any of the DVI female and male connectors may have become damaged.
    Ultimately can you try the monitor with another computer using a DVI cable, this will at least let you establish where any fault lies if nothing else does.
  7. Posts : 6
    Win 7
    If I disable the analog connection the digital doesn't work at all, it just says "power saving mode".
    In XP works fine as I stated before.
    I don't quite understand this question. Can you explain what you mean?
    I already installed the drivers, they are not specifically for W7 though.
    It is not damaged or anything, it works fine in other OSes
    Gonna try it, thanks for the advice.
  8. Posts : 1,614
    Yea, I did bend a pin one time. I was just hoping it wouldn't snap of when I was trying to re-posistion it.
  9. Posts : 1,614
    I;m getting old........
    I thought the iorceware drivers were fr the Nvidi card.
  10. Posts : 6
    Win 7
    And you are right, I have the latest nv card driver meaning I have the latest forceware, and also I tried the drivers LG supplies for the monitor itself.
