Windows 7: Installing HP 2710 wireless printer problems - offline?
22 Nov 2009   #1
windows vista ultimate
I did a clean install of Windows 7 enterprise on my Sony Vaio. I have an HP 2710 wireless printer that worked fine with Vista. I have tried installing it using the drivers from & using the 'find wireless' printer function found within Windows 7.
It had no problems with either method with the install but it keeps reading 'offline' and won't print wirelessly. I even tried downloading the Vista software but kept getting an error message.
2 questions - one, should I download using USB from the website OR let Windows 7 find the printer wirelessly (both work). Two, how can I get my printer to read 'online'?
30 Nov 2009   #2
I am having a similar problem with an Okidata C5150n Color Laserjet. It keeps showing "offline". There are no jams or errors on the printer. I am using a brand new Laptop and Desktop from Dell both with Win7. The printer has worked flawlessly for 5 yrs with a Dell emachine (now 8ys old) running Win2KPro and a 3yr old Toshiba Laptop running Vista. I downloaded the win7 64bit driver from Okidata last week. This is very annoying that it won't work correctly in Win7.
Search this Thread:
Advanced Search
Problems installing Canon MG6220 Wireless Printer in Win 7 x64
Bought this printer yesterday. After setting up the printer and installing the drivers from Canon I am presented with a message that the printer cannot be found on the network. I set up the wifi connection on printer, it found the access point and stated it was connected. The wifi light was on the...
Network & Sharing
Error message when installing wireless printer
I am trying to install my printer to my wireless network, but I keep getting an error message that I am not the administrator on this computer. This is my personal computer, so don't know why I would not be the administrator. I did set up a homegroup and add my printer and all my documents, but...
Hardware & Devices
Problems installing wireless printer on home network
I posted a thread previously, but still no luck -even took my computer to a repair store. I am on a Verizon FIOS wireless network. We have both a Toshiba and Sony computer. I downloaded the latest drivers for my HP Photosmart 6280 printer and was able to successfully install my printer...
Hardware & Devices
Wireless Printer Problems
:zip:Hi All I having a problem with my wireless printer I have Win7 32bit installed, printer is Brothers MFC-845CW, router is NETGEAR WNDR 3700 , I have checked the printer setup and printer connects to the router OK but when I try to print I get a error message saying something like (...
Network & Sharing
Wireless printer problems
I have a Lexmark x4530 printer using a Linksys Wireless G router; a HP laptop. Had some router to laptop issues and probably changed some settings. I cannot get the printer to print even after changing all settings back to factory, resetting the router. After using installation disc and cable,...
Hardware & Devices
Installing A Wireless Printer?
I have purchased a D-Link 1040 wireless print server and have connected it to my printer using a USB connection. I have installed the software. I turned the power on and pressed the little button on the side of the print server to enter search mode. In Windows 7 I tried adding a device but my...
Network & Sharing
